| » Light not going on |
Model Number: RM18F6WS Brand: Gibson Age: More than 10 years
Gibson Market Master refridgerator. The light doesn't go on. I changed the bulb and still no light. I checked the bulb in another socket and it works. I checked the switch at the bottom of the door with a current tester and there is a (weak) current coming to the swithch. I bought a switch from you and replaced it, still nothing. Before I move the fridge away from the wall and start following the wire around with a tester I thought I would ask you if this is a common problem with an easy solution. Is their a reset for the light circuit? Do you have a diagram of the wiring for the light? The rest of the fridge works fine.
Thanks Ads By Google Related Models |
What is the voltage you get at the switch?
Is it close to the voltage rating on the bulb? Unplug the refrigerator and look inside the socket that the bulb fits into. At the bottom of the socket there is a tab that connects to the bottom of the bulb to make the light come on. Look to see if that tab looks burnt and if so replace the socket. Sometimes all you have to do is bend the tab up so that it makes better contact. Refrigerator repair guide |
You were right! I tested the two points in the socket and got a full current. I guess the switch test was weak because the light bulb was completing the circuit up top and it was not making full contact. So I just bent the little peice of metal out a little, then put the bulb in and there is Light! (next time I might unplug the fridge first, but then how do you test? 120 isn't all that bad, as I just discovered. My dog barked as loud as I did and he was in the next room)
Thanks jvd |
| Display Modes | |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Wont run rinse light and cancel light blinking | vershell | Dishwasher Repair | 0 | 07-16-2009 12:45 PM |
| Replace light shield and bezel light | ryan88 | Refrigerator & Freezer Repair | 0 | 01-25-2009 06:56 AM |
| Microwave replacement Light bulb underneath light | sieglesx4 | Microwave Repair | 0 | 12-27-2008 07:52 AM |
| magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
