| » Freezer Coils iced over |
Model Number: GSS23SGSB Brand: GE Age: 5 - 10 years
The freezer on my GE GSS23SGSB side by side Fridge/freezer recently stopped cooling down to the correct temp. I removed the evarporator panel in the back of the freezer and found the evaporator coils completely frozen over. I defrosted the coils and put everything back together. 3 weeks later the freezer started warming up again. I removed the cover and the ice was back. I check the defrost heating element with a multi-meter it was an open circuit. I replaced the heating element 22 hrs ago but frost and ice are already starting to build up again.
Is there a way to force the heating element to come on to verify it works? I checked the thermometer when the freezer was at room temp and it read approx 6000 ohms. I cant find the defrost timer. I think it might controlled by the units control board but im not sure. Ads By Google Related Models Last edited by seholme1 : 04-20-2012 at 05:59 AM. |
Seholme, you're on the right track. With your tests and the parts you've replaced. your issue Could be in the "motherboard"
Part number: AP4436216 Your evaporator thermistor Part number: AP3185407 should have a resistance of 5K ohms resistance at 77 dgrs.F. And the defrost limit thermostat should be a "closed" circuit, below 110 dgrs. If all's OK then the Issue will be in the control board. Here's a quick test note: "With the refrigerator running, unplug it and remove the motherboard cover in the back. Locate the power connector in the bottom, left. Pull the connector off the motherboard and put a wire jumper between the connector pins that mate with the motherboard pins labeled line and def. Plug in fridge. If you now get defrost action in the freezer, you motherboard is probably bad. If no defrost, you have either a bad defrost heater, or defrost thermostat. In this way, you will be able to confirm which parts are bad." And here's a basic diagnostic/test programming information as you requested. Binder1.pdf Good Luck and Thanks
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thank you for the diagnostic sheet and the suggestoins.
Since the test codes are the least invasive i would liek to start with them, but i dont understand how to start the test. The instructions say "Press ay button other than a temp adjust button to begin the test." There are no other buttons. When i put in 1, 4 to start defrots nothing happened. The displays didnt flash and heater never turned on. That being said i couldnt figure out what other button to push to start the test. I tried some other test codes to see if any worked and none of them did anything. What am i missing? |
Quote:
You're not missing anything, This is my fault, I didn't notice that the "diagnostics" programming steps did not get included in the previous post. I've attached the complete diagnostics section of the service manual to this response, and you should be fine from here on out. Sorry, for the inconvenience. Good Luck and Thanks, Model GSS23SGSBSS https://docs.google.com/a/appliancep...NKnU0yrkENzLfQ
__________________
| Display Modes | |
| compressor running, no water dispensing from door, coils iced up, no evap fan runnin | cheap dutchman | Refrigerator & Freezer Repair | 0 | 05-30-2010 08:32 AM |
| Freezer coils iced up, evap fan does not run | slg321 | Refrigerator & Freezer Repair | 0 | 06-13-2009 02:58 PM |
| Freezer coils iced up | dcrockett3 | Refrigerator & Freezer Repair | 1 | 11-29-2008 07:04 PM |
| Evaporator Coils iced (refrigerator not cooling) | FZim | Refrigerator & Freezer Repair | 1 | 11-10-2008 07:38 PM |
| freezer coils iced up, trying to troubleshoot | anthonygeier | Refrigerator & Freezer Repair | 6 | 04-14-2008 08:13 AM |
