I Recently Had A Floor Put In And I Moved Very Carefully The Fridge. Upon Return To Same Place It Wasoriginally It Seems That The Fridge Tilts. I Tried Checking The 4 Wheels And They Seem Fine. What Else Could Be Causing This.
Groups: APP Team
Hi.
Try to adjust the rollers.
Simon.
Simon. How do I adjust the rollers? Thank you
Groups: APP Team
Hi.
Remove the bottom grill, locate the adjusting screw next to the roller one on each side. Using 1/4' hex driver turn the adjusting screws as needed.
Thank you.
Simon.
