Discuss
refrigerator freezer
 in
Refrigerator & Freezer Repair
not sure of the age however refrigerator is not cold and the freezer is working at about half of what
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator freezer
  #1 (permalink)
Old 08-11-2007, 05:16 AM
douville douville is offline
Junior Member
douville is on a distinguished road
Question refrigerator freezer
Model Number: gt22dk/gt22dm   Brand: Whirlpool   Age: 5 - 10 years
not sure of the age however refrigerator is not cold and the freezer is working at about half of what it should, not sure what to look at first, did not see the fan in the back of the freezer turning, felt that it should be, have shut it off for now any idea's.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-11-2007, 04:38 PM
jdman jdman is offline
Member
jdman is on a distinguished road
Default
If the condensor fan motor is not working, you found the problem.
  #3 (permalink)
Old 08-11-2007, 05:31 PM
Junior Member
Default
the condenser fan does work the fan located in the freezer portion of the refrigerator has not come on do not know what triggers it but believe it moves cold air to the refrigerator portion and circulates the cold air inside the freezer part also believe this may be the problem but do not know how to check it
  #4 (permalink)
Old 08-11-2007, 06:15 PM
Member
Default
Quote:
With the door open the evaporator fan will not run. You will have to oudh in on the door switch with your finger to see if it will come on or not.
  #5 (permalink)
Old 08-11-2007, 07:27 PM
Junior Member
Default
tried holding the switch and it does not come on
  #6 (permalink)
Old 08-11-2007, 08:59 PM
Member
Default
Before you shut the unit down and noticed that the fan was not running did you notice ice on the evaporator. You can chech the motor for continuity or you can unwire fan and wire to jumper cord to test. I beleive your motor has gone bad
  #7 (permalink)
Old 08-11-2007, 10:24 PM
Junior Member
Default
i reached in the freezer part and thru the grate that covers the fan turned it with a round file as it was the handist thing anyway it moved a little and i kept turning it and it started to spin slowly at first than at a faster speed it now is running at i think normal speed maybe it needs a drop of oil or has gummed up for some reason. will run it and see what it does
  #8 (permalink)
Old 08-12-2007, 08:04 AM
Member
Default
Glad you found the problem. Normally though when they start acting like this they are at the end of there life. You might want to order a motor and have it on hand. Then when it quits, you won't be down while your getting a motor. They are not expensive or hard to change out.
  #9 (permalink)
Old 08-14-2007, 10:18 AM
Junior Member
Smile
jdman thanks for your help it is nice to have it running again a new fan has been ordered.
Reply
« trace | dick2256 »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator not cooling, but freezer is working geri Refrigerator & Freezer Repair 18 09-18-2008 03:49 PM
Refrigerator/freezer problems imthewraith Refrigerator & Freezer Repair 3 09-17-2007 03:28 PM
Freezer/refrigerator not working Kevykev Refrigerator & Freezer Repair 3 08-09-2007 12:15 AM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Refrigerator/Freezer Caroline42 Refrigerator & Freezer Repair 1 07-20-2007 05:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
