Discuss
Maytag refrigerator stopped cooling, Freezer operating normal
 in
Refrigerator & Freezer Repair
Hi, We have been researching a lot on this forum under this topic, but are still having difficulty. From the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Maytag refrigerator stopped cooling, Freezer operating normal
  #1 (permalink)
Old 09-02-2009, 05:14 PM
Junior Member
brianfromwashington is on a distinguished road
Default Maytag refrigerator stopped cooling, Freezer operating normal
Model Number: MFD2561HEW   Brand: Maytag   Age: 1 - 5 years
We have been researching a lot on this forum under this topic, but are still having difficulty. From the information we gathered, we followed steps indicated on the different postings. We really don’t know much about refrigerator repairs, so your help would be greatly appreciated.
Our issue is similar to some of the postings about refrigerator not cooling and freezer is still working (0 degrees). The refrigerator suddenly stopped cooling and got warm. Initially, it the temperature indicator was flashing between two different numbers. One of them was 130 degrees. We checked the doors and kept the doors closed for a while and waited to see if it would get cooler. It got cooler, but the temperature was flashing again between two numbers, 60 degrees and 85 degrees.
This is what we have done so far to check and have tried to follow some of the advice from the other postings.
1. Checked the back panel in the lower freezer for frost or snow. There was some frost, but not a lot. We unplugged the refrigerator again, open the doors, and it appears that it is not cooling again.
2. We unplugged the refrigerator for 24 hours (took the food out). Waited for refrigerator to cool for 24 hours, and the refrigerator continued to flash the temperatures of 60 and 85.
3. We took panels off front and back of refrigerator and vacuumed and cleaned. There really wasn’t much build up of dirt, etc.
4. Checked fan in back and it is blowing and turning. Seems fine.
From what we understand so far, if the back panel has frost/snow, the evaporator coil is iced over and it is a defrost problem., but our attemps at defrosting the coil were unsuccessful. It seems that Maytag refrigerator’s commonly have problems with the defrost system (Evaporator heater and thermostat?). If there is no ice and it is clean, then it indicates that it’s probably the air diffuser (damper control) and it was recommended to also change the thermistor (temperature sensor).
Are we missing something? Could it be something different still? It is not clear exactly how to proceed now. How do we do further testing to know what it is. Do we just order the damper control and thermistor parts and replace them ourselves? Can we try to do this ourselves or do we need a experienced technician? Thanks for your help.
Brian
Ads By Google
Related Models
Maytag MFD2561HEW REF - BOTTOM MOUNTS
Maytag MFD2561KES REF - BOTTOM MOUNTS
Maytag MFD2562KEB10 REFRIGERATOR
Maytag MFD2562KEB11 REFRIGERATOR
Maytag MFD2562KES10 REFRIGERATOR
Maytag MFD2562KES11 REFRIGERATOR
Maytag MFD2562KEW10 REFRIGERATOR
Maytag MFD2562KEW11 REFRIGERATOR
Maytag MFD2562VEA1 REFRIGERATOR
Maytag MFD2562VEA10 REFRIGERATOR
Maytag MFD2562VEA2 REFRIGERATOR
Maytag MFD2562VEB1 REFRIGERATOR
Maytag MFD2562VEB10 REFRIGERATOR
Maytag MFD2562VEB2 REFRIGERATOR
Maytag MFD2562VEB3 REFRIGERATOR
Maytag MFD2562VEM1 REFRIGERATOR
Maytag MFD2562VEM10 REFRIGERATOR
Maytag MFD2562VEM2 REFRIGERATOR
Maytag MFD2562VEM3 REFRIGERATOR
Maytag MFD2562VEM4 REFRIGERATOR
Maytag MFD2562VEW1 REFRIGERATOR
Maytag MFD2562VEW10 REFRIGERATOR
Maytag MFD2562VEW2 REFRIGERATOR
Roper MFE14XW0 Microwaves*
Roper MFE14XW1 Microwaves*
Maytag MFF2258VEA10 REFRIGERATOR
Maytag MFF2258VEB10 REFRIGERATOR
Maytag MFF2258VEB2 REFRIGERATOR
Maytag MFF2258VEB3 REFRIGERATOR
Maytag MFF2258VEM2 REFRIGERATOR
Maytag MFF2258VEM3 REFRIGERATOR
Maytag MFF2258VEM4 REFRIGERATOR
Maytag MFF2258VEW10 REFRIGERATOR
Maytag MFF2258VEW2 REFRIGERATOR
Maytag MFF2557HEB REF - BOTTOM MOUNTS
Maytag MFF2557HEB14 REFRIGERATOR
Maytag MFF2557HEQ REF - BOTTOM MOUNTS
Maytag MFF2557HES REF - BOTTOM MOUNTS
Maytag MFF2557HEW REF - BOTTOM MOUNTS
Maytag MFF2557KES REF - BOTTOM MOUNTS
Maytag MFF2558KEB REF - BOTTOM MOUNTS
Maytag MFF2558KEB11 REFRIGERATOR
Maytag MFF2558KES REF - BOTTOM MOUNTS
Maytag MFF2558KES12 REFRIGERATOR
Maytag MFF2558KEW REF - BOTTOM MOUNTS
Maytag MFF2558KEW11 REFRIGERATOR
Maytag MFF2558VEA1 REFRIGERATOR
Maytag MFF2558VEA10 REFRIGERATOR
Maytag MFF2558VEA2 REFRIGERATOR
Maytag MFF2558VEB1 REFRIGERATOR
Maytag MFF2558VEB10 REFRIGERATOR
Maytag MFF2558VEB2 REFRIGERATOR
Maytag MFF2558VEB3 REFRIGERATOR
Maytag MFF2558VEM1 REFRIGERATOR
Maytag MFF2558VEM10 REFRIGERATOR
Maytag MFF2558VEM2 REFRIGERATOR
Maytag MFF2558VEM3 REFRIGERATOR
Maytag MFF2558VEM4 REFRIGERATOR
Maytag MFF2558VEQ1 REFRIGERATOR
Maytag MFF2558VEQ10 REFRIGERATOR
Maytag MFF2558VEQ2 REFRIGERATOR
Maytag MFF2558VEW1 REFRIGERATOR
Maytag MFF2558VEW10 REFRIGERATOR
Maytag MFF2558VEW2 REFRIGERATOR
Frigidaire MFF312BFWB Frg(v1) / Electric Range
Frigidaire MFF312BFWC Frg(v2) / Electric Range
Frigidaire MFF312BFWE Frg(v3) / Electric Range
Frigidaire MFF312BSF ELECTRIC RANGE
Frigidaire MFF312HSC ELECTRIC RANGE
Frigidaire MFF318BGDA Wwh(v1) / Electric Range
Frigidaire MFF318BGWA Wwh(v2) / Electric Range
Frigidaire MFF351BCWC Frg(v1) / Electric Range
Frigidaire MFF351BCWD Frg(v2) / Electric Range
Frigidaire MFF351BCWE Frg(v3) / Electric Range
Maytag MFI2067AEB REF - BOTTOM MOUNTS
Maytag MFI2067AEB12 REFRIGERATOR
Maytag MFI2067AEB13 REFRIGERATOR
Maytag MFI2067AEB4 REFRIGERATOR
Maytag MFI2067AEB5 REFRIGERATOR
Maytag MFI2067AEQ REF - BOTTOM MOUNTS
Maytag MFI2067AEQ12 REFRIGERATOR
Maytag MFI2067AEQ13 REFRIGERATOR
Maytag MFI2067AEQ4 REFRIGERATOR
Maytag MFI2067AES REF - BOTTOM MOUNTS
Maytag MFI2067AES12 REFRIGERATOR
Maytag MFI2067AES13 REFRIGERATOR
Maytag MFI2067AES4 REFRIGERATOR
Maytag MFI2067AES5 REFRIGERATOR
Maytag MFI2067AES6 REFRIGERATOR
Maytag MFI2067AEW REF - BOTTOM MOUNTS
Maytag MFI2067AEW12 REFRIGERATOR
Maytag MFI2067AEW13 REFRIGERATOR
Maytag MFI2067AEW4 REFRIGERATOR
Maytag MFI2266AEB10 REFRIGERATOR
Maytag MFI2266AEB11 REFRIGERATOR
Maytag MFI2266AEQ10 REFRIGERATOR
Maytag MFI2266AEQ11 REFRIGERATOR
Maytag MFI2266AES10 REFRIGERATOR
Maytag MFI2266AES11 REFRIGERATOR
Maytag MFI2266AEU10 REFRIGERATOR
Maytag MFI2266AEU11 REFRIGERATOR
Maytag MFI2266AEW10 REFRIGERATOR
Maytag MFI2266AEW11 REFRIGERATOR
Maytag MFI2269VEA1 REFRIGERATOR
Maytag MFI2269VEA10 REFRIGERATOR
Maytag MFI2269VEB1 REFRIGERATOR
Maytag MFI2269VEB10 REFRIGERATOR
Maytag MFI2269VEB2 REFRIGERATOR
Maytag MFI2269VEM1 REFRIGERATOR
Maytag MFI2269VEM10 REFRIGERATOR
Maytag MFI2269VEM2 REFRIGERATOR
Maytag MFI2269VEM3 REFRIGERATOR
Maytag MFI2269VEQ1 REFRIGERATOR
Maytag MFI2269VEQ10 REFRIGERATOR
Maytag MFI2269VEW1 REFRIGERATOR
Maytag MFI2269VEW10 REFRIGERATOR
Maytag MFI2568AEB REF - BOTTOM MOUNTS
Maytag MFI2568AEB12 REFRIGERATOR
Maytag MFI2568AEB13 REFRIGERATOR
Maytag MFI2568AEQ REF - BOTTOM MOUNTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer & Refrigerator Both Stopped Cooling byznme Refrigerator & Freezer Repair 1 09-13-2009 01:04 PM
Maytag Plus Marginally cooling freezer and refrigerator microflight Refrigerator & Freezer Repair 1 05-16-2009 09:39 AM
Refrigerator stopped cooling Myfamof8 Refrigerator & Freezer Repair 1 05-04-2009 08:25 AM
Refrigerator stopped cooling off Sojubandit Refrigerator & Freezer Repair 1 04-17-2009 02:14 AM
Refrigerator smoking, then stopped cooling trelawny Refrigerator & Freezer Repair 3 11-07-2008 12:30 PM
