the refrigerator is not coming on at all after it was cleaned.Is there a reset button somewhere or do i just change the circuit board?
THIS FORUM IS DEAD!!!!!!! |
No lights at all and i already did those.i left it off overnight and have the same result.
Here is a wiring diagram http://manuals.frigidaire.com/p...f/Anderson/241636601.pdfAs you can see there is not a fuse or circuit breaker that will kill power to the entire unit. Have you checked the voltage at the outlet or tried a different outlet? If you have voltage at the outlet then you will have to check for voltage getting to the fridge. |
