| » fridge turns on but no fan and does not get cold |
Model Number: rs22aqxgw03 Brand: Roper Age: 5 - 10 years
I have a roper side by side that stopped working when plugged in the light inside comes on and ice maker works but the fridge does not get cold as well as the freezer.
Quote:
A bit confused, you state the IM works but the freezer nor fresh food is cooling. Not sure how the IM is producing ice if the freezer isn't cold. Can you hear the compressor running? Hear the fan in the freezer running?
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
What I mean is the ice machine motor i guess when you close the door and push the ice despenser in the motor that makes ice come out inside the ice box, its not producing any ice sorry for the confusion. But up until about 2 hrs ago the fan would come on for about 30 min than turn off but now the only thing it does when plugged in is the lights come on inside. thats it. i don't here any fans or compressors come on.
Quote:
Gotcha. First thing I would look at is the defrost timer. It maybe stuck in the defrost mode. You'll find the timer located in the control panel, where your dials are. It appears you can access the turn screw through a small round opening. Using a flat blade screwdriver you can turn it and see if you hear a click and see if the unit starts up. If it does your timer is bad. There is also the potential for the cold control/thermostat being bad. It's also shown in the below link. Look under the control housing picture. Part number: AP3110896 Model RS22AQXGW03
__________________
Quote:
Quote:
I wasn't implying they were both bad. It was "it's probably one or the other" from what you explained. If you heard the compressor start when you turned the defrost timer then I say that is bad. Hearing the compressor clicking and not starting isn't a good thing. Was it doing that before the unit went silent?
__________________
| Display Modes | |
| GE fridge cold, freezer not cold enough | mattsteele64 | Refrigerator & Freezer Repair | 11 | 12-26-2012 08:51 AM |
| Whirpool fridge won't get cold in fridge/freezer. HELP! | Cynthia McDaniel | Refrigerator & Freezer Repair | 1 | 01-16-2010 11:40 AM |
| Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold | dieselgg | Refrigerator & Freezer Repair | 5 | 06-19-2009 04:51 AM |
| freezer.fridge not cold and leaking into fridge | fruitul | Refrigerator & Freezer Repair | 1 | 09-08-2008 03:20 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
