Discuss
Drip Hole Freezing Up
 in
Refrigerator & Freezer Repair
Water puddles have been in front of the freezer door. I took everything out, removed FROZEN sheet of ice from
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Drip Hole Freezing Up
  #1 (permalink)
Old 08-31-2009, 08:53 AM
Jeeves Jeeves is offline
Junior Member
Jeeves is on a distinguished road
Default Drip Hole Freezing Up
Model Number: KSRS25ILWH02   Brand: Kitchen Aid   Age: Less than 1 year
I took everything out, removed FROZEN sheet of ice from bottom of freezer area.
Found frozen ice around/in drip tray below some coils below the 'air flow' area in the lower portion of freezer.
With hair dryer, defrosted everything and verified no obstruction and clean hole to tray UNDER the freezer.
A couple days later, I noticed the hole is CLOGGED again...
Something is not heating or defrosting????
Related Models
Whirlpool KSRS25ILWH02 Refrigerator
Whirlpool KSRS25ILWH03 Refrigerator
Whirlpool KSRS25ILWH13 Refrigerator
Whirlpool KSRS25KGAL00
Whirlpool KSRS25KGBL00
Whirlpool KSRS25KGBL01
Whirlpool KSRS25KGBL02
Whirlpool KSRS25KGBL03
Whirlpool KSRS25KGBT01
Whirlpool KSRS25KGBT02
Whirlpool KSRS25KGBT03
Whirlpool KSRS25KGWH00
Whirlpool KSRS25KGWH01
Whirlpool KSRS25KGWH02
Whirlpool KSRS25KGWH03
Whirlpool KSRS25PNBL00 Refrigerator
Whirlpool KSRS25PNBT00 Refrigerator
Whirlpool KSRS25PNLK00 Refrigerator
Whirlpool KSRS25PNSS00 Refrigerator
Whirlpool KSRS25PNWH00 Refrigerator
Whirlpool KSRS25QAAL00
Whirlpool KSRS25QAAL01
Whirlpool KSRS25QAAL02
Whirlpool KSRS25QAAL10
Whirlpool KSRS25QAAL11
Whirlpool KSRS25QAWH00
Whirlpool KSRS25QAWH01
Whirlpool KSRS25QAWH02
Whirlpool KSRS25QAWH10
Whirlpool KSRS25QAWH11
Whirlpool KSRS25QDAL00
Whirlpool KSRS25QDAL01
Whirlpool KSRS25QDAL03
Whirlpool KSRS25QDWH00
Whirlpool KSRS25QDWH01
Whirlpool KSRS25QDWH03
Whirlpool KSRS25QFAL00
Whirlpool KSRS25QFBL00
Whirlpool KSRS25QFWH00
Whirlpool KSRS25QGAL00
Whirlpool KSRS25QGAL01
Whirlpool KSRS25QGAL02
Whirlpool KSRS25QGAL03
Whirlpool KSRS25QGAL04
Whirlpool KSRS25QGAL05
Whirlpool KSRS25QGBL00
Whirlpool KSRS25QGBL01
Whirlpool KSRS25QGBL02
Whirlpool KSRS25QGBL03
Whirlpool KSRS25QGBL04
Whirlpool KSRS25QGBL05
Whirlpool KSRS25QGBT02
Whirlpool KSRS25QGBT03
Whirlpool KSRS25QGBT04
Whirlpool KSRS25QGBT05
Whirlpool KSRS25QGWH00
Whirlpool KSRS25QGWH01
Whirlpool KSRS25QGWH02
Whirlpool KSRS25QGWH03
Whirlpool KSRS25QGWH04
Whirlpool KSRS25QGWH05
Whirlpool KSRS25QWAL11
Whirlpool KSRS25QWAL13
Whirlpool KSRS25QWWH11
Whirlpool KSRS25QWWH13
Whirlpool KSRS25QXAL00
Whirlpool KSRS25QXAL10
Whirlpool KSRS25QXAL11
Whirlpool KSRS25QXWH00
Whirlpool KSRS25QXWH10
Whirlpool KSRS25QXWH11
Whirlpool KSRS25RSBL00 Refrigerator
Whirlpool KSRS25RSBL01 Refrigerator
Whirlpool KSRS25RSBT00 Refrigerator
Whirlpool KSRS25RSBT01 Refrigerator
Whirlpool KSRS25RSMK00 Refrigerator
Whirlpool KSRS25RSMK01 Refrigerator
Whirlpool KSRS25RSMS00 Refrigerator
Whirlpool KSRS25RSMS01 Refrigerator
Whirlpool KSRS25RSWH00 Refrigerator
Whirlpool KSRS25RSWH01 Refrigerator
Whirlpool KSRS25RVBL00 Refrigerator
Whirlpool KSRS25RVMK00 Refrigerator
Whirlpool KSRS25RVMS00 Refrigerator
Whirlpool KSRS25RVWH00 Refrigerator
Whirlpool KSRS27CNBL00 Refrigerator
Whirlpool KSRS27CNBT00 Refrigerator
Whirlpool KSRS27CNSS00 Refrigerator
Whirlpool KSRS27CNWH00 Refrigerator
Whirlpool KSRS27FGAL00
Whirlpool KSRS27FGAL01
Whirlpool KSRS27FGBL00
Whirlpool KSRS27FGBL01
Whirlpool KSRS27FGBL02
Whirlpool KSRS27FGBL03
Whirlpool KSRS27FGBL04
Whirlpool KSRS27FGBT00
Whirlpool KSRS27FGBT01
Whirlpool KSRS27FGBT02
Whirlpool KSRS27FGBT03
Whirlpool KSRS27FGBT04
Whirlpool KSRS27FGSS11
Whirlpool KSRS27FGSS13
Whirlpool KSRS27FGSS14
Whirlpool KSRS27FGWH00
Whirlpool KSRS27FGWH01
Whirlpool KSRS27FGWH02
Whirlpool KSRS27FGWH03
Whirlpool KSRS27FGWH04
Whirlpool KSRS27IHBL00
Whirlpool KSRS27IHBL02
Whirlpool KSRS27IHBT00
Whirlpool KSRS27IHBT02
Whirlpool KSRS27IHSS00
Whirlpool KSRS27IHSS02
Whirlpool KSRS27IHWH00
Whirlpool KSRS27IHWH02
Whirlpool KSRS27IKBL01
Whirlpool KSRS27IKBL02
Whirlpool KSRS27IKBT01
  #2 (permalink)
Old 09-02-2009, 04:50 PM
applianceman applianceman is offline
Senior Member
applianceman is on a distinguished road
Default
The best way to clean this hole is with a turkey baser. Force water down the drain until water flows freely. Then mix water with baking soda and pour it down the drain. Refrigerator repair guide
  #3 (permalink)
Old 09-03-2009, 04:27 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
You may also want to remove/check the drip tray under the unit, sometimes the drain tube can be partially clogged here due to dust.
I recommend you flush the drain tube with a 10% bleach solution to kill the crud growing in the tube.
If all this fails there is a jiggery pokery fix for this. Take a bare copper piece of 14 gauge wire, wrap this around the bottom of the heater, then route it down the drain tube a couple inches.
The theory is that the wire will heat up during the defrost cycle and help keep the drain clear of ice. You only want it to get warm so only do a couple wraps around the heater.
I only recommend this as a last resort.
__________________
  #4 (permalink)
Old 09-03-2009, 08:29 AM
Junior Member
Default
Thanks denam... especially for helping a app-newbie. In the KitchenAid (circa 2003) model KSRS25ILWH02[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?
I can't figure out how to manuver the the (bottom) drip tray out.. It's mostly blocked by the water filter.
In addition, I have been able to unscrew the aluminum cover that is covering the air flow supply, and the coils, but I haven't figured out the magical angle to remove this cover without having to remove they tray TRACKS and/or scratching the inside of the freezer. Do I have to remove the tracks?
I read also where a water mixture of backing soda is suggested...
Oh, I wouldn't even call this a tube - it's so big and short - I would call it a plug in a way
Regarding the 'fix', I found the heater element, part AP298898 identified in the "UNIT PARTS" - From below, where about is this? I'm trying to avoid pulling the unit out... The coils are a little dusty and based on the triangular fashion, how the heck does one clean them? Think I should just use my compressor and use another vacuum to channel the dust to the vacuum? There is no way anyone can clean those coils easily!
Anyway, TIA!
  #5 (permalink)
Old 09-12-2009, 10:20 AM
mharrison mharrison is offline
Junior Member
mharrison is on a distinguished road
Default
[quote=Jeeves;123856]Thanks denam... especially for helping a app-newbie. In the KitchenAid (circa 2003) model KSRS25ILWH02[url="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?
Anyway, TIA![/QUOTE]
I'm grateful to Denman for his suggestion to remove the Drain pan - mine has the crud of ages in it and it needs cleaning.
Question: Can I get the drain pan out from the back of the refrig. with it still standing upright? Or will I need to tilt the refrig on its side to expose the underneath?
Thanks.
Mike
  #6 (permalink)
Old 09-12-2009, 10:23 AM
Junior Member
Default
Thanks Denman>
How do I get the drip pan out? Can I do it with the refrig standing upright? Or do I need to tilt it on its side to expose the underneath?
Thanks.
Mike
  #7 (permalink)
Old 09-12-2009, 05:28 PM
Senior Expert
APP Volunteer
Default
Cannot say for sure but usually you should be able to get it out through the front once the kick plate is removed.
Hopefully someone with actual experience on this unit will jump in and help out.
If not, start a new thread with the Model Number and "How to remove the drip tray"
Some folks on this forum seem a little shy on adding to another expert's advice. I will not reply so others will be more more open to replying.
PS: I am not an expert just a fix-it-man as my kids used to call me.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water drip pan keith82901 Refrigerator & Freezer Repair 1 07-17-2009 07:58 PM
water drip pan keith82901 Refrigerator & Freezer Repair 0 07-17-2009 02:25 PM
Fountain drip Jeff Beach Refrigerator & Freezer Repair 1 02-26-2009 08:03 PM
drip, drip, drip. drip,drip >>>>>>>>>>> gac5000 Refrigerator & Freezer Repair 0 02-06-2009 01:12 PM
Drip from Inside at the Top KC John Washer Repair 0 07-27-2007 09:31 AM
