| » water leak |
Model Number: hotpoint ge hsm25 gfta sa Brand: Hotpoint Age: 5 - 10 years
just got used unit and dont know much about it. Cools fine and makes ice. When i put glass in door to get water none comes out, but i hear pump pumping and water goes on the floor under unit on freezer side.
You need to take a close look at the water line that is between the water inlet valve and the dispenser to find the leak.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Based on the source on the leaky water heater, the difficulty can be effectively sorted out by only tightening up screws which usually keep the pressing assistance valve, and it may well end up in boiler change. Many factors that cause water heater leaking will be from the pipes links or gaskets of the power alleviation device. Also, it is plausible that the trigger from the dripping trouble is because water lines getting in as well as away from the water boiler.
| Display Modes | |
| Dishwasher water leak near water pump | frogger63 | Dishwasher Repair | 1 | 11-25-2011 02:43 AM |
| water leak in front of refrigerator when using water dispenser | RichardCh | Refrigerator & Freezer Repair | 0 | 08-10-2009 10:29 AM |
| water leak in back from water line | TRUSTART | Refrigerator & Freezer Repair | 1 | 04-05-2009 07:01 AM |
| Water leak | Randy2828 | Refrigerator & Freezer Repair | 1 | 08-09-2008 10:52 PM |
| Water Leak | BMcIntyre | Refrigerator & Freezer Repair | 0 | 10-02-2007 08:12 AM |
