Discuss
refrig warm, freezer cold
 in
Refrigerator & Freezer Repair
refrig is warm, but freezer works fine. no ice on coils, fan blowing fine. no air blowing from vent in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrig warm, freezer cold
  #1 (permalink)
Old 01-20-2008, 11:37 AM
rosalind48 rosalind48 is offline
Junior Member
rosalind48 is on a distinguished road
Default refrig warm, freezer cold
Model Number: asd2620hrz   Brand: Amana   Age: 1 - 5 years
refrig is warm, but freezer works fine. no ice on coils, fan blowing fine. no air blowing from vent in refrig very disgusted need hep before food spoils again this happened last month , then appeared tp correct itself. i thought it was because the freezer was packed with food, covering up the air vent, but thats not the case.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-20-2008, 11:44 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
and you definitely check for ICE on the EVAPORATOR coils ( coils inside freezer ? )
__________________
regards
jim
  #3 (permalink)
Old 01-22-2008, 04:05 PM
Junior Member
Default amana asd2620rhz
We Took The Back Panel Off Of The Refrig And I Did Not See Ice On The Coils, And The Fan Was Blowing. I NEED TO FIGURE OUT HOW TO CHECK THE EVAPORATOR COILS FOR ICE. I THOUGHT THE EVAPORATOR COILS WERE TO DRY UP WASTE WATER, UNLESS ICE ON THE COILS MEANS SOMETHING IS AWRY.
Last edited by rosalind48 : 01-22-2008 at 04:09 PM. Reason: LEFT OUT SOMETHING OF IMPORTANCE
  #4 (permalink)
Old 01-22-2008, 10:29 PM
Senior Expert
APP Volunteer
Default
while the compressor is running you should have FROST on the evaporator coils ( those coils in the FREEZER ) ... the evaporator coils absorb HEAT which leaves cold air ... ( condenser coils beneath refrige, disappates heat into the room allowing refrigerant to return to absorb more heat ! )
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer Cold,But refrig warm (Side/Side) oceanrunner Refrigerator & Freezer Repair 5 12-28-2007 10:19 PM
Freezer Cold,But refrig warm oceanrunner Refrigerator & Freezer Repair 1 11-23-2007 07:32 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 03:58 AM
Freezer blows cool but not freezing and refrig is warm Angelicas Refrigerator & Freezer Repair 2 08-08-2007 09:06 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 06:43 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
