Refrigerator suddenly stopped running overnight. The light inside the refrigerator still works but cooling and freezer is not working. I unplugged the refrigerator to test for power. Power is fine, however when I plug it back in the refrigerator sounds like it is starting to run but quits withing 30 seconds. I repeated the procedure but had the same results! What should I check for?
