| » Refrigerator is 45 and freezer is at 32? |
Model Number: MZD2766GEQ Brand: Maytag Age: 5 - 10 years
The freezer reads 32 and the frig reads 45,the fan and compressor are running.I replaced ,adaptive defrost encl.,temp control assembly and overload switch?Thank you for your time,pwcarson.
Here are your parts includes a wiring diagram.
Replacement parts for Maytag MZD2766GEQ REF - SXS/I&W | AppliancePartsPros.com You said the compressor and fan is running, is the evaporator/freezer fan also running? It is required to pull air through the coils to cool it efficiently. Is the compressor warm and can you feel it vibrating? I am assuming that it runs constantly other than perhaps when it goes into a defrost cycle. If yes remove the cover from inside the freezer so you can inspect the evaporator coils. If the coils are heavily iced/frosted over you have a defrost problem. If there is just frost in one area (usually where the freon enter the coils) you have a sealed system problem. This check must be done after the compressor has run for at least a couple hours, if you do it shortly after a defrost cycle you will reach the wrong diagnosis. If it is a sealed system problem it will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit. Below is a link that may be useful. http://www.applianceaid.com/refrigerator.html Take a look at #20 and then the example pictures part way down the page.
__________________
| Display Modes | |
| Magic Chef Refrigerator Freezer work Refrigerator not cold enough | tg06222 | Refrigerator & Freezer Repair | 1 | 09-05-2011 03:56 AM |
| Refrigerator/Freezer stopped working after defrosting freezer drain | lymiller | Refrigerator & Freezer Repair | 0 | 03-26-2011 05:40 AM |
| Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm | 808BigShorty | Refrigerator & Freezer Repair | 2 | 02-23-2011 01:04 PM |
| frost free refrigerator/freezer frosting over on back wall or bottom freezer | bwheeler | Refrigerator & Freezer Repair | 2 | 01-31-2011 07:16 AM |
| Moved refrigerator, freezer fine but refrigerator is too warm | tigerjim | Refrigerator & Freezer Repair | 1 | 06-09-2010 10:59 AM |
