| » GE Refrigerator frosted over/fan running |
Model Number: GSS25SGMD Brand: GE Age: 5 - 10 years
Freezer is frosted over on the coils and around the icemaker. Fan will not stop at any setting other then 0. I had an issue with the water valve and water line to the icemaker a few weeks ago and both have been replaced. The reason I bring this up is because the water line into the icemaker was freezing up and it split the line on the backside of the unit. It looks like water ran down and got inside the motherboard compartment. The actual board was not wet but need to understand if maybe this was causing the continuous running of the fan and the frosted coils or maybe another defective part.
Thanks Ads By Google Related Models |
Is it snow looking frost or is it hard ice? If it is hard ice it could have been from your previous icemaker issue. The issue you describe about the icemaker could have caused water to leak onto the coils causing hard ice to form. If this is the case all you should have to do is melt the ice because you already took care of the problem.
If it is snowy frost you could have a defrost problem which could be caused the water on the motherboard but I would eliminate the other three possibilities first. (Especially since you don’t know for sure if the board got wet). The defrost heater, defrost thermostat or the evaporator thermistor could be the problem. Take a look at this page it should help Refrigerator Defrost Problem Diagnostics Oh and the fan is going to run most of the time until you take care of the frosting problem. Last edited by applianceman : 04-04-2012 at 09:03 AM. |
| Display Modes | |
| Frosted freezer | Keith Gross | Refrigerator & Freezer Repair | 0 | 09-01-2011 12:19 PM |
| Frosted Evaporator Coils | smicky | Refrigerator & Freezer Repair | 0 | 09-09-2009 07:49 PM |
| Iced/Frosted Evap. Coil | mi_1204 | Refrigerator & Freezer Repair | 6 | 09-05-2009 05:01 PM |
| frosted dishware | potter | Dishwasher Repair | 1 | 06-19-2009 05:25 AM |
| Freezer frosted up after I turned power off | tmadams | Refrigerator & Freezer Repair | 3 | 10-10-2007 02:19 AM |
