Discuss
Refrigerator freezing
 in
Refrigerator & Freezer Repair
Freezer too cold and Refrig freezing food. I cleaned lint, replaced the defrost thermostat, tested defrost heater ( its Good).
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator freezing
  #1 (permalink)
Old 04-03-2012, 12:00 PM
Junior Member
dmkuhner@yahoo.com is on a distinguished road
Default Refrigerator freezing
Model Number: KSRA25ILSS13   Brand: Kitchen Aid   Age: 5 - 10 years
Freezer too cold and Refrig freezing food. I cleaned lint, replaced the defrost thermostat, tested defrost heater ( its Good). What else can I do or test before I get a repair guy or replace control board?? Thanks, Debbie
Ads By Google
Related Models
Whirlpool KSRA25ILSS13 Refrigerator
Whirlpool KSRA25ILWH00 Refrigerator
Whirlpool KSRA25ILWH01 Refrigerator
Whirlpool KSRA25ILWH03
Whirlpool KSRA25ILWH13 Refrigerator
Whirlpool KSRA25KKBL00
Whirlpool KSRA25KKBL01
Whirlpool KSRA25KKBL02 Refrigerator
Whirlpool KSRA25KKBL12 Refrigerator
Whirlpool KSRA25KKBT00
Whirlpool KSRA25KKBT01
Whirlpool KSRA25KKBT02 Refrigerator
Whirlpool KSRA25KKBT12 Refrigerator
Whirlpool KSRA25KKSS00
Whirlpool KSRA25KKSS01
Whirlpool KSRA25KKSS02 Refrigerator
Whirlpool KSRA25KKSS12 Refrigerator
Whirlpool KSRA25KKWH00
Whirlpool KSRA25KKWH01
Whirlpool KSRA25KKWH02 Refrigerator
Whirlpool KSRA25KKWH12 Refrigerator
Whirlpool KSRA25KNSS00 Refrigerator
Whirlpool KSRA25KNSS01 Refrigerator
Whirlpool KSRA25PNBL00 Refrigerator
Whirlpool KSRA25PNBT00 Refrigerator
Whirlpool KSRA25PNLK00 Refrigerator
Whirlpool KSRA25PNSS00 Refrigerator
Whirlpool KSRA25PNWH00 Refrigerator
Whirlpool KSRB22DWAL02
Whirlpool KSRB22DWWH02
Whirlpool KSRB22FGBL00
Whirlpool KSRB22FGSS00
Whirlpool KSRB22FGWH00
Whirlpool KSRB22FHBL00
Whirlpool KSRB22FHBL01
Whirlpool KSRB22FHBL02
Whirlpool KSRB22FHBL03
Whirlpool KSRB22FHBL04
Whirlpool KSRB22FHBL05
Whirlpool KSRB22FHBL06
Whirlpool KSRB22FHBT01
Whirlpool KSRB22FHBT02
Whirlpool KSRB22FHBT03
Whirlpool KSRB22FHBT04
Whirlpool KSRB22FHBT05
Whirlpool KSRB22FHBT06
Whirlpool KSRB22FHSS00
Whirlpool KSRB22FHSS01
Whirlpool KSRB22FHSS02
Whirlpool KSRB22FHSS03
Whirlpool KSRB22FHSS04
Whirlpool KSRB22FHSS05
Whirlpool KSRB22FHSS06
Whirlpool KSRB22FHWH00
Whirlpool KSRB22FHWH01
Whirlpool KSRB22FHWH02
Whirlpool KSRB22FHWH03
Whirlpool KSRB22FHWH04
Whirlpool KSRB22FHWH05
Whirlpool KSRB22FHWH06
Whirlpool KSRB22FKBL00
Whirlpool KSRB22FKBL01
Whirlpool KSRB22FKBL02
Whirlpool KSRB22FKBL03 Refrigerator
Whirlpool KSRB22FKBL04 Refrigerator
Whirlpool KSRB22FKBL14 Refrigerator
Whirlpool KSRB22FKSS00
Whirlpool KSRB22FKSS01
Whirlpool KSRB22FKSS02
Whirlpool KSRB22FKSS03 Refrigerator
Whirlpool KSRB22FKSS04 Refrigerator
Whirlpool KSRB22FKSS14 Refrigerator
Whirlpool KSRB22FNSS00 Refrigerator
Whirlpool KSRB22FRBX00 Refrigerator
Whirlpool KSRB22FRBX01 Refrigerator
Whirlpool KSRB22FRBX02 Refrigerator
Whirlpool KSRB22FTBX00 Refrigerator
Whirlpool KSRB22QABL00
Whirlpool KSRB22QABL10
Whirlpool KSRB22QABL11
Whirlpool KSRB22QABL12
Whirlpool KSRB22QDBL00
Whirlpool KSRB22QDBL01
Whirlpool KSRB22QDBL02
Whirlpool KSRB22QFBL00
Whirlpool KSRB22QFBL01
Whirlpool KSRB22QFSS00
Whirlpool KSRB22QFSS01
Whirlpool KSRB22QGBL00
Whirlpool KSRB22QGSS00
Whirlpool KSRB22QXAL00
Whirlpool KSRB22QXBL00
Whirlpool KSRB22QXWH00
Whirlpool KSRB25FBBL00
Whirlpool KSRB25FGBL00
Whirlpool KSRB25FGBT00
Whirlpool KSRB25FGSS00
Whirlpool KSRB25FGWH00
Whirlpool KSRB25FHBL00
Whirlpool KSRB25FHBL01
Whirlpool KSRB25FHBL02
Whirlpool KSRB25FHBL03
Whirlpool KSRB25FHBL04
Whirlpool KSRB25FHBL05
Whirlpool KSRB25FHBT00
Whirlpool KSRB25FHBT01
Whirlpool KSRB25FHBT02
Whirlpool KSRB25FHBT03
Whirlpool KSRB25FHBT04
Whirlpool KSRB25FHBT05
Whirlpool KSRB25FHSS00
Whirlpool KSRB25FHSS01
Whirlpool KSRB25FHSS02
Whirlpool KSRB25FHSS03
Whirlpool KSRB25FHSS04
Whirlpool KSRB25FHSS05
Whirlpool KSRB25FHWH00
Whirlpool KSRB25FHWH01
Whirlpool KSRB25FHWH02
Whirlpool KSRB25FHWH03
  #2 (permalink)
Old 04-06-2012, 03:11 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is your parts breakdown.
Replacement parts for Whirlpool KSRA25ILSS13 REFRIGERATOR | AppliancePartsPros.com
Looks like there is a vent lower down on the wall between the freezer and fresh food sides. Check that it is not being blocked by food etc.
If blocked then cold air can collect at the bottom of the fresh food side and freeze food.
Try running the diagnostics.
Adjust the fresh food temperature to see if the diffuser/damper (Item 15 in Section 10) closes. If you click on it's picture a new page will open with a Q&A section.
For some reason I cannot attach the tech sheet so I hope you have found it.
I will try starting another post to attach it.
__________________
  #3 (permalink)
Old 04-06-2012, 03:16 AM
Senior Expert
APP Volunteer
Default
Second try attaching the tech sheet.
__________________
  #4 (permalink)
Old 04-08-2012, 08:39 AM
Junior Member
Default
hi, thanks for responding. Was camping so now am back and will try tomorrow your suggestions. But right before I left I ran the diagnostics. The air baffle seems to be the only thing not working. The fan worked when I ran it alone but did not work when with the baffle , number 5, I think. So knowing this, should just replace the air baffle?? Debbie
  #5 (permalink)
Old 04-08-2012, 11:16 AM
Senior Expert
APP Volunteer
Default
Not quite sure what you are referring to
The baffle is Item 15 in Section 10, I think.
The fan and baffle are controlled seperately so I am not sure what is happening here.
__________________
  #6 (permalink)
Old 04-09-2012, 12:11 PM
Junior Member
Default
What I mean is that number 5 on the diagnostic test is to test the air baffle. That is the only test that did not work. I had another set of instructions that said the fan motor should come on when on test #5,,,it did not. However the fan worked when it was tested earlier in the diagnostics (when tested by itself) So thats why I ask if I should remove and test air baffle. And how do I do this? Debbie,,,,thanks
  #7 (permalink)
Old 04-10-2012, 05:05 AM
Senior Expert
APP Volunteer
Default
Here is a manual which should help
http://appliancejunk.com/forums/inde...=view;down=215
You may hav to join the site to download the manual but it is free and this is a good site for the appliance DIYer.
You will need a meter to check the switch and to check for power to the motor when in test 5
Looks like S2 baffle should be closed (0 ohms) when the baffle door is fully open. Also it is open (infinite ohms) when the door is fully closed or opening.
__________________
  #8 (permalink)
Old 04-11-2012, 09:18 AM
Junior Member
Default
HI, Just wanted to tell you that when the power is on,,,and in Diagnostic Test 5 , I hear baffle motor trying to come and black wire tests hot and yellow/red (switch , I think) tests not hot . So to test the baffle/diffuser we should put ohm meter probe on black and the other on yellow /red,,,With power on and in Test 5,,,correct?? I didn't want to hurt anything else.
  #9 (permalink)
Old 04-11-2012, 09:19 AM
Junior Member
Default
Also,,,can we take motor apart and fix something in it rather that replaying whole baffle/diffuser part.??
  #10 (permalink)
Old 04-12-2012, 02:58 AM
Senior Expert
APP Volunteer
Default
No. You cannot use ohms (resistance) with the power on.
It could blow your meter.
Individual parts for the motor/baffle are not available.
Looking back at your original post you did say that the freezer was too cold.
The baffle does not effect this so you may have more than one problem.
The freezer should be between 0 and 5 degrees F.
Also if you click on the below picture of the baffle/diffuser a page will open with a Q&A section that may be helpful.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator Freezing Chevyman Refrigerator & Freezer Repair 2 07-14-2012 06:08 PM
Refrigerator freezing up tclabare Refrigerator & Freezer Repair 4 06-22-2011 03:26 PM
Refrigerator freezing queensroe Refrigerator & Freezer Repair 0 02-01-2010 07:52 AM
Amana Refrigerator Freezing in Refrigerator cdodson1 Refrigerator & Freezer Repair 4 05-10-2009 08:12 PM
refrigerator freezing everything dbares1 Refrigerator & Freezer Repair 2 10-26-2007 03:09 PM
