In replacing the defrost switch the new unit has fewer terminals then the old one. The new part number is WPL 482493 description Timer-def
The loose black wire on the switch was placed on termianl 1 of the unit.
However the refrig has a green wire that was attached to a terminal on the side of the OLD switch --- What do I do with it?
Your new defrost timer does not need this ground wire. Also, mark the new defrost timer knob and make sure the timer advances, you may have misswired it.
