Discuss
GE - No water to door - but ice maker works
 in
Refrigerator & Freezer Repair
Have GE TPX24PPDABB. No water coming from dispenser in door. No water coming from water line under freezer door. Before
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE - No water to door - but ice maker works
  #1 (permalink)
Old 08-24-2009, 06:34 PM
Junior Member
SterlingGray is on a distinguished road
Default GE - No water to door - but ice maker works
Brand: GE   Age: 5 - 10 years
Have GE TPX24PPDABB. No water coming from dispenser in door. No water coming from water line under freezer door. Before it failed, it appeared the water valve was getting stuck and would take a few seconds to open and close.
I see there are two water valves AP2071735 and 36. Which do I need?
Or can i use a newer one AP3672839?
Do I need to replace the wiring harness?
I'm pretty handy - is this a DIY project?
Ads By Google
  #2 (permalink)
Old 08-24-2009, 07:08 PM
Junior Member
Default Correction
My wife turned of the water while I was doing some troublshooting....
Have water to door - but when dispenser pad is released water still flows for about 10 seconds gradually decreasing to a thin stream and then dripping for about 2 seconds. Is this a sign that water valve is sticking or not closing? It turns on quickly with full flow in 0.5 seconds.
So same question - Which water valve or replacement parts do I need
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water works but not to the Ice Maker rmacbeth Refrigerator & Freezer Repair 1 12-31-2009 10:46 AM
water not getting to hose from pump but water dispencer works not ice maker sharbrat Refrigerator & Freezer Repair 0 07-29-2009 10:38 AM
Water dispenser works but not for ice maker alinbuckeye Refrigerator & Freezer Repair 0 03-30-2009 09:42 PM
Ice maker works but no water is being supplied to it HenrySiegel Refrigerator & Freezer Repair 4 03-30-2009 07:46 PM
Ice maker will not draw water but water in door works normally kg1okc Refrigerator & Freezer Repair 3 01-26-2008 02:57 PM
