I replaced a burnt solenoid and arm assy for cube/crushed ice (#AP2071947). Testing afterwards reveal the ice dispensing auger won't turn and water won't dispense. However, water was dispensed into the ice maker but hasn't harvested yet. Is there a fuse that may have blown or do you suspect the control board. If so, where are they located? Thanks, Mike.
Groups: APP Team
Hi. Do you hear if solenoid you replaced energizing when you push the lever? If not, check for 120v at the solenoid contacts with door switch closed and ice lever pushed. If there is no 120v - check the micro switch inside the ice and water dispenser. If the switch checks OK, then most likely the problem is bad control board inside the dispenser. The control board Part number: AP2071639
Thank you. Post the results. Simon.
