The dispenser for the water and ice does not work. The Funnel Ice Dispenser does not pop out so when I put a glass in it does not push in. I had it looked at and the repair man said that the spring was broke or missing and in order to fix it I would need to replace the entire door. Is this true?
Thanks,
John Black
