Discuss
refridgerator won't defrost
 in
Refrigerator & Freezer Repair
My roper refridgerator keeps icing up. I have taken it apart and defosted the coils with a hair dryer and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refridgerator won't defrost
  #1 (permalink)
Old 03-29-2012, 06:33 PM
Junior Member
jeremybanal is on a distinguished road
Default refridgerator won't defrost
Model Number: rt21lmxkq00   Brand: Roper   Age: More than 10 years
My roper refridgerator keeps icing up. I have taken it apart and defosted the coils with a hair dryer and it works for a few days and then it freezes up again. Does anyone know what the problem might be?
Ads By Google
Related Models
Whirlpool RT21LMXKQ00
Whirlpool RT21LMXKQ01
Whirlpool RT21LMXKQ02
Whirlpool RT21LMXKQ03 Refrigerator
Whirlpool RT21LMXKQ04 Refrigerator
Whirlpool RT21LMXKQ05 Refrigerator
Whirlpool RT21LMXKQ06 Refrigerator
Whirlpool RT21LMXKQ07
Whirlpool RT21LMXKQ08 Refrigerator
Whirlpool RT21LMXKQ09 Refrigerator
Whirlpool RT21LMXKQ10 Refrigerator
Whirlpool RT21LMXKT00
Whirlpool RT21LMXKT01
Whirlpool RT21LMXKT02
Whirlpool RT21LMXKT03 Refrigerator
Whirlpool RT21LMXKT04 Refrigerator
Whirlpool RT21LMXKT05 Refrigerator
Whirlpool RT21LMXKT06 Refrigerator
Whirlpool RT21LMXKT07
Whirlpool RT21LMXKT08 Refrigerator
Whirlpool RT21LMXKT09 Refrigerator
Whirlpool RT21LMXKT10 Refrigerator
Whirlpool RT21SKXJN00
Whirlpool RT21SKXJW00
Whirlpool RT21SKXLQ00
Whirlpool RT21SKXLQ01
Whirlpool RT21SKXLQ02 Refrigerator
Whirlpool RT22AKXBL00
Whirlpool RT22AKXBW00
Whirlpool RT25BKXAL00
Whirlpool RT25BKXAW00
Whirlpool RT25BKXZL00
Whirlpool RT25BKXZL01
Whirlpool RT25BKXZW00
Whirlpool RT25BKXZW01
Maytag RTC1500AAL Ref - Top Mount
Maytag RTC1500AAW Ref - Top Mount
Maytag RTC1500CAE Ref - Top Mount
Maytag RTC1500CAL Ref - Top Mount
Maytag RTC1500CAW Ref - Top Mount
International RTC1500CGE Ref - Top Mount
Maytag RTC1500DAE Ref - Top Mount
Maytag RTC1500DAM Ref - Top Mount
Maytag RTC15A Ref - Top Mount
Maytag RTC1700AAL Ref - Top Mount
Maytag RTC1700AAW Ref - Top Mount
Maytag RTC1700CAE Ref - Top Mount
Maytag RTC1700CAL Ref - Top Mount
Maytag RTC1700CAW Ref - Top Mount
Maytag RTC1700DAE Ref - Top Mount
Maytag RTC1700DAM Ref - Top Mount
Maytag RTC17A Ref - Top Mount
Maytag RTC1900AAL Ref - Top Mount
Maytag RTC1900AAW Ref - Top Mount
Maytag RTC1900CAE Ref - Top Mount
Maytag RTC1900CAL Ref - Top Mount
Maytag RTC1900CAW Ref - Top Mount
Maytag RTC19A Ref - Top Mount
  #2 (permalink)
Old 03-30-2012, 02:19 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Roper RT21LMXKQ00 REFRIGERATOR | AppliancePartsPros.com
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 4 in Section 4) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 6 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 8 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Does my Maytag have a defrost timer or adaptive defrost control? Where is it? Momto8 Refrigerator & Freezer Repair 13 06-18-2012 06:37 PM
Replaced Defrost bulb and Defrost Sensor....Temps in freezer around 6 degrees mnmtwi Refrigerator & Freezer Repair 3 10-17-2011 08:46 AM
Kenmore Refridgerator defrost system failure Ranger0001 Refrigerator & Freezer Repair 4 01-14-2010 05:04 AM
I still have froze in the freezer after changing defrost timer & bi-metal defrost matteson Refrigerator & Freezer Repair 0 12-29-2009 06:25 PM
Amana Bottom Freezer Refridgerator Defrost Issue RycherGirl Refrigerator & Freezer Repair 1 11-11-2009 02:38 AM
