depascoe
#1 Posted : Thursday, March 29, 2012 8:09:31 AM(UTC)
depascoe
I have a Samsung refrig My freezer was working fine but my refrig side was 50 so I took of my panel in the refrig and found out the evaporator was all iced up. That worked. Now four weeks later it happened again so i did the same thing . While i had it apart i checked my heater with a ohm meter for continuity. It was fine.so I put all back together plugged in the refrig and this time the front display would not light up except for a half of a digit which flashes. The compressor does not run. I cannot see why just by unplugging the refrig this happened and does anyone know what the foam pieces do on the sides of the evaporator separateing the heater and the coil.
#2 Posted : Thursday, March 29, 2012 12:37:36 PM(UTC)
Perform the troubleshooting as described in the attached file. Post the results.
Here are the breakdown diagrams and Replacement parts for Samsung RS2544SL REF - SXS | AppliancePartsPros.com
File Attachment(s):
RS2542 Fast track.pdf (1,702kb) downloaded 3 time(s).
depascoe
#3 Posted : Saturday, March 31, 2012 8:21:11 PM(UTC)
depascoe
Well the frig now works fine but still worrying if it will evap coil will still ice up. the defrost heater has continuity. So what do i replace now to stop the iceing problem I do not mind replacing an extra part The main board is probably good I hope but that will be my last thing to do.
David (Washer Repair)
by David J Robertson 3/14/2014 8:08:07 AM(UTC)
david (Refrigerator & Freezer Repair)
by glennspace 4/28/2013 7:15:53 AM(UTC)
David (Refrigerator & Freezer Repair)
by Shut up 7/5/2012 8:01:23 AM(UTC)
David (Oven Repair (including Ranges and Cooktops))
by David57 10/26/2011 11:45:50 AM(UTC)
by dcrowles 4/3/2010 6:20:26 PM(UTC)
Lee Davidian (Dryer Repair)
by LeeDavidian 1/31/2010 4:55:09 PM(UTC)
