Discuss
icemaker/water inlet valve check
 in
Refrigerator & Freezer Repair
A few months ago, the water from the door stopped working, couple of weeks ago the icemaker stopped working. both
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » icemaker/water inlet valve check
  #1 (permalink)
Old 01-17-2008, 01:10 PM
rks rks is offline
Junior Member
rks is on a distinguished road
Default icemaker/water inlet valve check
Model Number: ed25cqxhw00   Brand: Whirlpool   Age: 5 - 10 years
A few months ago, the water from the door stopped working, couple of weeks ago the icemaker stopped working. both cases, dont see water is coming. Possibly I need to replace the water inlet valve, however I would like to know if it is water inlet valve or the wiring. Is there a way to check whether the water inlet valve is ok or not before I replace it. the part no. is 2182106.
thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-18-2008, 01:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Pull the fridge off and check if there is an in line water filter on the back.
If there is one - it could be clog due to age.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-18-2008, 05:24 PM
rks rks is offline
Junior Member
Default
there is no water fliter, the pipe straight goes into the inlet valve, which seems to have two soloenoids (?). with two water pipes for water and icemaker, water seems to be making into the inlet valve, however not from the the valve. Is it possible to check the inletvalve with some multimeter to make sure it is not working before I replace it. How do I check the wiring, if valve is OK.
thanks a lot for your time.
  #4 (permalink)
Old 01-19-2008, 02:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are the two solenoids with the two water tubes as you mentioned.
The 1/4" tube for the ice maker water line and the 5/16" tube for the water dispenser line.
Remove the electric plug from the water dispenser solenoid and check for 120V across the plug terminals while someone else push the water dispenser lever.
If there is 120V then the water valve is bad and has to be replaced.
If there is no 120V then the problem with the water dispenser or wires.
If there is 120V to the water dispenser solenoid, put the water dispenser plug on the ice maker solenoid and check if water will flow to the ice maker.
- The part number for the water inlet valve is AP3085178
Here are the break down diagrams for the Whirlpool refrigerator Model ED25CQXHW00
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
repair or replace water inlet valve richard1520 Washer Repair 1 12-17-2007 10:51 PM
New Water Inlet valve has different fittings cubbedges Refrigerator & Freezer Repair 2 10-27-2007 09:38 AM
Maytag Washer Inlet valve - water level switch reisman Washer Repair 0 10-23-2007 09:36 PM
Water inlet valve m/c Refrigerator & Freezer Repair 2 07-31-2007 11:34 PM
Water inlet valve gentleben Refrigerator & Freezer Repair 1 07-19-2007 12:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
