Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   GE refrig need to locate the defrost timer? (http://forum.appliancepartspros.com/refrigerator-freezer-repair/44803-ge-refrig-need-locate-defrost-timer.html)
bobbertj 08-19-2009 12:08 PM
My freezer coils are frozen up and I need to locate the defrost timer.I know that you can manually turn them to see if the heater is working.I starting seeing water on the floor and the food section was not as cold as it should be.This part I'm trying to locate is not showing:confused: on your parts breakdown.Thank You
Gene 08-19-2009 02:55 PM
There is no defrost timer in your refrigerator. The defrost cycle operates by the main control board on the back of the refrigerator.
You can use the instructions from one of our previous posts addressed to bohemian: http://forum.appliancepartspros.com/...oo-warm-3.html
Here are the breakdown diagrams and Replacement parts for GE GSS22JFMDWW | AppliancePartsPros.com
NAKIARUTH 05-25-2011 01:22 PM
Ge Refrigerator Not Cool Enough
My ge refrigerator is no cooling on the refrigerator side.The freezer side was icing up.I changed the mother board.Cause the condenser fan stop working .Now the board has been changed.Model #gsh25kgrbbb
Gene 05-25-2011 02:39 PM
There is no defrost timer in your refrigerator. It operates by the main control board on the back of the refrigerator.
What exactly is wrong with the refrigerator?
Did you perform any troubleshooting yet?
Here are the breakdown diagrams and Replacement parts for General Electric GSH25KGRBBB Refrigerator | AppliancePartsPros.com
charmntim 02-13-2013 07:06 AM
locationof derost timer in GE gbs20kbpawn
Can you tell me where the defrost timer is located and how to adjust it ....thanks please GE gbs20kbpawn:mad: :( :confused:
Gene 02-13-2013 08:18 PM
Quote:
You just quoted one of my previous posts which says "there is no defrost timer". In the other thread http://forum.appliancepartspros.com/...-warm-183.html you mentioned that the repair guy replaced the main control board to fix it.
I really don't understand why now you are looking for a defrost timer in the same refrigerator?
What is wrong with the refrigerator now?
Here are the breakdown diagrams and Parts for GE GBS20KBPAWW Refrigerator - AppliancePartsPros.com
