Hi - this fridge came with the house when I bought it so I don't really know how old it is. Originally the icemaker was working but about a month ago it stopped working. I'm not really sure what to look for or how to troubleshoot to figure out what's the issue. Any advice would be appreciated.
Thanks.
Sound just like my Refrigerator. Most ice makers come with a metal bar (looks like a wire) that stick out of the side of the ice maker and wraps around from front to back horizontally. IF that bar is stick straight out, the ice make will stop working. it must be in the down position, against a bottom corner of the ice make for it to start working again. Just push down gently with your hand and see if you hear it start working again.
If not, then more details are needed.
Thanks for the reply but already checked that. When its on you hear the sound of the water i guess loading but still no ice being made. Suggest anything else to try?
