| » Maytag french door fridge freezer on bottom |
Model Number: 10884272er Brand: Maytag Age: 1 - 5 years
noticed last night Freezer was warmer than normal and ice maker not making any ice. all contents were thawed. fridge above is working normal.
freezer makes buzzing sound with a click at the end every few minutes Ads By Google Related Models |
Quote:
That is not a real good sign. If the noise you're hearing is the compressor trying to start and the overload then kicking it off you may have a compressor problem. Depending on the age of the unit, you may want to get a hold of an authorized servicer, the compressor may still be under warranty.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
You need to get us a good model number first for me to look up the part. The one you listed isn't a valid #. I can get you a price for the part, but the labor piece will vary. It it will expensive though. Just guessing but, somewhere between $350 up to $600. You'll need to pull the unit out from the wall and get behind it. There is a fan back there that keeps the comp running cool, make sure it's running. When you're back there, if you wait a few minutes, if it's the comp you'll hear it try and start. If it's already running when you're back there, then you can probably rule it out. From your description it does sound like it though.
__________________
Quote:
If the compressor isn't running it will sure affect both sections. Have you done what I mentioned in my previous post? Below is the part number for the compressor and price is $248.83. You'll have to check with local servicers to find out how much they would charge you for the installation if that is the problem. Part number: AP3179960
__________________
| Display Modes | |
| LG French Door / Bottom Freezer Door Hinge Cam Broken - Looking for install procedure | ServicePlus | Refrigerator & Freezer Repair | 14 | 04-23-2011 10:45 PM |
| Maytag French Door Fridge OD. | knittingtrains | Refrigerator & Freezer Repair | 4 | 11-11-2010 02:09 PM |
| GE French door bottom freezer lights don't work | Carloppriori | Refrigerator & Freezer Repair | 1 | 06-13-2009 05:31 PM |
| LG- French Door Bottom Freezer is cold but refrigeration warm | ktmguy | Refrigerator & Freezer Repair | 6 | 01-16-2009 02:35 PM |
| maytag freNch door fridge | martinezc2006 | Refrigerator & Freezer Repair | 19 | 02-27-2008 05:34 PM |
