I purchased a new refridgerator and moved the Maytag to another room and plugged it in. The GFI kept tripping so I replaced the GFI with the same result. I then plugged the fridge into a non GFI outlet and it now stayed on.
The refridgerator now does not get cold. The freezer is very cold and the fridge seems to not be cooling correctly.
I don't know if there is a temp sensor that may be faulty or something similar.
I know that the GFI trips if there is a 10mA differential, so i thought there is a problem in the fridge.
Please advise.
