My side by side Frigidaire is freezing my food on the refride side. The freezer side seems to be working fine. When I open the door on the refridgerator side the fan in the back keeps working also. I thought that when you open the door the fan cuts out.. also it was blowing out some frost. I have since turned down the temp. controls on both, but my food is still freezing. I was told that it may be the damper. Any help would be appreciated. Thanks
