Discuss
IceMaker not getting any water
 in
Refrigerator & Freezer Repair
I have an icemaker that quit working. Water from the water dispenser works fine. I turned down the temp on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » IceMaker not getting any water
  #1 (permalink)
Old 08-16-2009, 09:26 PM
Junior Member
sund is on a distinguished road
Default IceMaker not getting any water
Model Number: SXD25S2L   Brand: Amana   Age: More than 10 years
I have an icemaker that quit working. Water from the water dispenser works fine. I turned down the temp on the freezer to see if the water dispenser tube had frozen over. I left it that way overnight. I then turned it to max cold to see if that would help and that didn't either. Any ideas?
Thanks,
Sun
Ads By Google
Related Models
Amana SXD25S2L Ref - SXS/I&W
Amana SXD25S2W Ref - SXS/I&W
Amana SXD26VE Ref - SXS/I&W
Amana SXD26VL Ref - SXS/I&W
Amana SXD26VW Ref - SXS/I&W
Amana SXD27NE Ref - SXS/I&W
Amana SXD27NL Ref - SXS/I&W
Amana SXD27NW Ref - SXS/I&W
Amana SXD27Q2E Ref - SXS/I&W
Amana SXD27Q2L Ref - SXS/I&W
Amana SXD27Q2W Ref - SXS/I&W
Amana SXD27TE Ref - SXS/I&W
Amana SXD27TL Ref - SXS/I&W
Amana SXD27TW Ref - SXS/I&W
Amana SXD322L Ref - SXS/I&W
Amana SXD322S2L Ref - SXS/I&W
Amana SXD322S2W Ref - SXS/I&W
Amana SXD322W Ref - SXS/I&W
Amana SXD520NW Ref - SXS/I&W
Amana SXD520SL Ref - SXS/I&W
Amana SXD520SW Ref - SXS/I&W
Amana SXD520TE Ref - SXS/I&W
Amana SXD520TW Ref - SXS/I&W
Amana SXD522VE Ref - SXS/I&W
Amana SXD522VW Ref - SXS/I&W
Amana SXD524VE Ref - SXS/I&W
Amana SXD524VW Ref - SXS/I&W
Amana SXDE25J Ref - SXS/I&W
Amana SXDE25JB Ref - SXS/I&W
Amana SXDE25JP Ref - SXS/I&W
Amana SXDE27NE Ref - SXS/I&W
Amana SXDE27NL Ref - SXS/I&W
Amana SXDE27NPE Ref - SXS/I&W
Amana SXDE27NPL Ref - SXS/I&W
Amana SXDE27NPW Ref - SXS/I&W
Amana SXDE27NW Ref - SXS/I&W
Amana SXDE27QE Ref - SXS/I&W
Amana SXDE27QL Ref - SXS/I&W
Amana SXDE27QW Ref - SXS/I&W
Amana SXDE522K Ref - SXS/I&W
Amana SXDE522M Ref - SXS/I&W
Amana SXDE526K Ref - SXS/I&W
Amana SXDE526M Ref - SXS/I&W
Amana SXDE528MW Ref - SXS/I&W
Amana SXDT22H Ref - SXS/I&W
Amana SXDT25H Ref - SXS/I&W
Amana SXDT522J Ref - SXS/I&W
Amana SXDT522K Ref - SXS/I&W
Amana SXDT522M Ref - SXS/I&W
Amana SXDT526J Ref - SXS/I&W
Whirlpool SXF300W0
Whirlpool SXF300W1
Whirlpool SXF300W2
Whirlpool SXF300W3
Whirlpool SXF300W4
Whirlpool SXF325W0
Whirlpool SXF325W1
Whirlpool SXF325W2
Whirlpool SXF330W0
Whirlpool SXF330W1
Whirlpool SXF350W0
Whirlpool SXF400W0
Whirlpool SXF400W1
Whirlpool SXF400W2
Whirlpool SXF400W3
Whirlpool SXF400W4
Whirlpool SXF430W0
Whirlpool SXF440W0
Whirlpool SXF440W1
Whirlpool SXF450W0
Whirlpool SXF500W0
Whirlpool SXF500W1
Whirlpool SXF500W2
Whirlpool SXF500W3
Whirlpool SXF500W4
Whirlpool SXF500W5
Whirlpool SXF530W0
Whirlpool SXF530W1
Whirlpool SXF530W2
Whirlpool SXF600W0
Whirlpool SXF600W1
Whirlpool SXF600W2
Whirlpool SXF600W3
Whirlpool SXF600W4
Whirlpool SXF600W5
  #2 (permalink)
Old 08-17-2009, 05:48 AM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
Quote:
Thanks,
Sun
Could be a number of different things. Possibly the fill line where the water enters the back of the freezer is frozen over and not allowing water to enter the IM. Might be the water valve which sends water up to the IM. Some of these models have more then one valve involved. Do you possibly have the "P" number that is on the ID plate? That differentiates the different revisions on this model.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-17-2009, 08:45 AM
Junior Member
Default
Thanks for the quick reply. The part number is: P1190407W L. From your post, it looks like i should go to the external back of the refridgerator and check for a line directly to the ice maker as well as check the valve there.
  #4 (permalink)
Old 08-17-2009, 09:31 AM
Senior Expert
Default
The water valve is located in the back of the refrig. It's what your house water line connects to on the rear of the refrig. Below is a picture with the part #. The spot where I mentioned it might be froze is in the freezer section where that tube goes into the fill cup of the IM. Although when your behind the unit you could disconnect the plastic line that goes up the back wall feeding your IM, and blow through it to see if its clear.
Part number: AP4134853
__________________
  #5 (permalink)
Old 08-17-2009, 09:33 PM
Junior Member
Default
The line from the water valve to the IM appears to be clear and not frozen. Would you suggest trying to replace the water valve first?
Thanks,
Sun
  #6 (permalink)
Old 08-18-2009, 05:08 AM
Senior Expert
Default
Thanks,
Sun
I don't like guessing, but there's a good chance it may be the valve. The only real way to prove it is to have a volt meter handy and check to see if it's getting power when the IM goes through a harvest mode.
__________________
  #7 (permalink)
Old 08-18-2009, 06:27 AM
Junior Member
Default
I was searching around the site and one suggestion was to switch the plugs on the valve to see if water would come out of the dispenser. Does that apply in this situation as well. I never hear the valve making any noise so it would be tough to go the volt meter route. If it is to switch the plugs, do I switch the 2 plugs one one side with the other 2 on the other?
  #8 (permalink)
Old 08-18-2009, 06:46 AM
Senior Expert
Default
You can try that. You'll have to push the water dispenser button to send power to the valve. If water shoots into the IM then you know the valve is ok. Don't hold down on the dispenser too long or you'll have water all over your freezer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No water to icemaker 49er Refrigerator & Freezer Repair 0 01-11-2010 01:19 PM
Water to Icemaker 12kramer Refrigerator & Freezer Repair 3 08-14-2009 03:07 PM
Icemaker not getting water kevin biddulph Refrigerator & Freezer Repair 3 03-06-2009 06:48 PM
No water to icemaker, water dispenser works BobK898 Refrigerator & Freezer Repair 6 01-16-2009 01:49 PM
No water to icemaker beaubo1 Refrigerator & Freezer Repair 0 11-30-2007 10:50 AM
