| » Gss22jfpaww |
It sounds like your refrigerator is in liner protection mode, which means your door switch isn’t working.
Take a look at your fresh food door and see if it has dropped down lower than the freezer door. If so adjust the door back up so that it hits the door switch well and your problem should be solved. GE Refrigerator Repair Guide |
There is an adjustment screw at the bottom hinge. Even if you see the light cut off still adjust the door up and see if this takes care of your problem. If not you may have a thermistor issue.
Did you read the instructions with the board? There is a section that talks about cutting a jumper wire on some models. If yours is one of the models you need to cut the jumper. I am not 100% sure what happens if you don’t cut out the jumper but you need to do so if yours is one of the models listed on the instructions. However if it is not on the list do not cut any wires. |
The board directions said for bottom drawer models only I did not cut any wires and I have wondered about this and reread them. my luck I have an odd ball that needs the jumper cut and the directions dont specify it. Mine is a side by side. I did replace the thermister yesterday as well as all 3 of the sensors. Raised the door.
No it said to cut the jumper on bottom mounts and some encoder models. Yours is an encoder model but only some serial numbers apply. There is a list of serial numbers on the board instructions that corresponds to the models you must cut the wire.
Again do not cut the wire unless instructed on the sheet provided with the board. |
| Display Modes | |
