andysimpson76
#1 Posted : Saturday, August 15, 2009 8:20:49 PM(UTC)
andysimpson76
My refrigerator is not cooling. The fan on the back works, the lights inside the refrigerator work but the inside of the refrigerator and freezer are not cold. No iced up walls in freezer. Already cleaned the coils behind the kick panel. Still not working. From what I have read, it seems like it is most likely the compressor and I may need a hard start kit. Does that seem to be true? If so, are all hard start kits the same (ie will work on any model refrigerator/compressor)? Thanks for your help.
andysimpson76
#2 Posted : Monday, August 17, 2009 6:25:59 AM(UTC)
andysimpson76
anyone? need to get this fixed today.
#3 Posted : Monday, August 17, 2009 1:08:45 PM(UTC)
What is the complete model number of the refrigerator?
andysimpson76
#4 Posted : Monday, August 17, 2009 6:01:46 PM(UTC)
andysimpson76
kenmore 106.52702100
#5 Posted : Monday, August 17, 2009 6:25:41 PM(UTC)
If the fan motor on the back is working then the compressor must work as well. They should work together. You can touch the compressor to make sure if it's working.
If the compressor is not working then you can try to replace the start relay. If it would not help then the compressor itself has gone bad. Such repair is very costly but if it is less than half of price for a new refrigerator and your old fridge is still in good shape then it could be worth fix it.
- The star relay Part number: AP3885081
andysimpson76
#6 Posted : Monday, August 17, 2009 7:11:32 PM(UTC)
andysimpson76
Is it easy to replace the start relay? I called a refrigerator repairman today and he couldn't come for a couple of days, but he also mentioned the hard start to essentially jump start the compressor. Would this work? If so, what's the difference in doing putting in a hard start vs. the start relay? Do you sell the hard start kits?
ps I did touch the compressor. Doesn't seem to be working (not humming or anything).
thanks for all of your help
#7 Posted : Tuesday, August 18, 2009 11:50:31 AM(UTC)
You can install a hard start 3-in-1 device instead of OEM start relay, but keep in mind:
1. It can damage the control board
2. If a compressor needs a hard start kit, it is most probably on its deathbed anyhow
The 3-in-1 hard start device Part number: AP4319922
