| » water filter malfunction causes short in control panel |
Model Number: FRS6L7EES9 Brand: Frigidaire Age: 5 - 10 years
I found water on the shelves in my fridge this morning. I believe the water filter had a malfunction. I changed the filter and didn't notice a problem.
Now the big problem is my duel control board fried and the label panel warped. I assume I will need a new wire harness as well. I'm comfortable replacing these items but I do not know what caused the flood. Could the Damper controller or the evaporator fan been the culprit? I also worry the the base water filter could have just gone bad. If i buy a new one will an o'ring come with it or must i buy that separately? Thank you for your time Ads By Google Related Models |
Quote:
On the other side a bad water filter base can be the culprit. O'ring can not be purchased separately. - The water filter base Part number: AP3687338 Here are the breakdown diagrams and Replacement parts for Frigidaire FRS6L7EES9 Frigidaire/refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thank you Gene.
I'll order the Duel Digital Control & the water filter base. I see the wire harness would take some time to get to me; think the likelihood of being able to reuse the same one is good? Quote:
Did you see a real damage to the wire harness?
__________________
Yes there is damage to the wiring harness. Turns out there was a small electrical fire at the duel control board connector; the wires are fused to the board.
Think the rest of the unit could be damaged from this trauma? |
Most likely not, but you'll never know until you'll try.
__________________
The duel digital control is now blinking for and failing to come to temperature.
suggestions? |
Quote:
__________________
Yes the duel digital control is flashing 4 on the right side.
I'm told this is the compressor. Is it safe to say i need to replace the compressor? |
Flashing 4 on the right side points to a problem with the damper control.
- The damper control Part number: AP3772850 Gene. P.S. Have you replaced the wire harness too?
__________________
| Display Modes | |
| Control Panel Display Malfunction | crash365 | Oven Repair (including Ranges and Cooktops) | 1 | 12-23-2011 10:57 AM |
| Maytag Wall oven control panel malfunction | dgen6 | Oven Repair (including Ranges and Cooktops) | 0 | 11-29-2011 04:52 AM |
| removing front control panel assembly to take out broken water filter housing | enyart | Refrigerator & Freezer Repair | 1 | 08-03-2011 01:26 PM |
| Control Panel Malfunction | Brian Miller | Refrigerator & Freezer Repair | 0 | 02-11-2011 02:47 PM |
| Control Panel Malfunction | Franco De Palo | Oven Repair (including Ranges and Cooktops) | 0 | 04-01-2009 05:38 PM |
