Discuss
water filter malfunction causes short in control panel
 in
Refrigerator & Freezer Repair
Originally Posted by Gene Flashing 4 on the right side points to a problem with the damper control. - The
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water filter malfunction causes short in control panel
  #11 (permalink)
Old 04-03-2012, 07:20 PM
Junior Member
wowaaron is on a distinguished road
Default Duel Digital Control blinking 4
Quote:
- The damper control Part number: AP3772850
P.S. Have you replaced the wire harness too?
I have replaced the wire harness too.
The Fridge is warm also.
Wouldn't the compressor try to work without the damper fan functioning?
  #12 (permalink)
Old 04-04-2012, 01:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by wowaaron View Post
...Wouldn't the compressor try to work without the damper fan functioning?
Does the compressor work or it does not? Does it make any noise? Does it click?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 04-04-2012, 01:29 PM
Junior Member
Default warm fridge
How would i go about checking the compressor for functionality?
I kept the unit plugged in over night to see if it would cool; it stayed warm.
The damper fans functionality would hamper the unit from trying to cool would it?
  #14 (permalink)
Old 04-04-2012, 01:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the refrigerator out of the wall. Remove the bottom cover and check the compressor on touch. Is it vibrating? Is it cold, warm or hot on touch?
I'm not sure which parts did you call "damper fans".
__________________
  #15 (permalink)
Old 04-04-2012, 01:57 PM
Junior Member
Default warm fridge
The damper control Part number: AP3772850, sorry.
would it cause the unit to not cool?
  #16 (permalink)
Old 04-04-2012, 02:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...would it cause the unit to not cool?...
The fresh food compartment only. The freezer should be cold anyway.
P.S. Try to unplug the refrigerator for a few minutes.
__________________
  #17 (permalink)
Old 04-04-2012, 02:07 PM
Junior Member
Default warm fridge and freezer
The freezer did not cool the night i had it plugged in. I will check the compressor. What else could be the problem if not the compressor?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control Panel Display Malfunction crash365 Oven Repair (including Ranges and Cooktops) 1 12-23-2011 10:57 AM
Maytag Wall oven control panel malfunction dgen6 Oven Repair (including Ranges and Cooktops) 0 11-29-2011 04:52 AM
removing front control panel assembly to take out broken water filter housing enyart Refrigerator & Freezer Repair 1 08-03-2011 01:26 PM
Control Panel Malfunction Brian Miller Refrigerator & Freezer Repair 0 02-11-2011 02:47 PM
Control Panel Malfunction Franco De Palo Oven Repair (including Ranges and Cooktops) 0 04-01-2009 05:38 PM
