Discuss
Evaporator motor part #wr60x10185
 in
Refrigerator & Freezer Repair
Evaporator motor in freezer makes howling noises. It runs normal speed, then runs slow and struggling, back and forth. All
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Evaporator motor part #wr60x10185
  #1 (permalink)
Old 01-14-2008, 10:30 PM
seahawkman seahawkman is offline
Junior Member
seahawkman is on a distinguished road
Default Evaporator motor part #wr60x10185
Model Number: gsh25jfrfww   Brand: GE   Age: 1 - 5 years
Evaporator motor in freezer makes howling noises. It runs normal speed, then runs slow and struggling, back and forth. All else works fine, any help please on what to do or replace, thanks, Ken
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 03:03 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Replace the motherboard in the back, there is a new board, so you will have to call to get the replacement.
__________________
  #3 (permalink)
Old 01-15-2008, 04:49 AM
Junior Member
Default
So the fan motor is not the problem? How does the mother board work into this problem? Ive seen other blogs on different sites, where people have replaced that motor to fix the problem.Thanks for help!
  #4 (permalink)
Old 01-15-2008, 07:46 AM
Senior Expert
APP Volunteer
Default
You have the infamous motherboard that sends different frequencies to the evaporator motor as a function of cooling needs. If you had a frequency meter, you would see this change as the evaporator fan changes.
__________________
  #5 (permalink)
Old 01-15-2008, 06:08 PM
Junior Member
Default
so the new mother boards are updated, with no problems ? I have heard the old one had problems, thanks for the help!
  #6 (permalink)
Old 01-16-2008, 02:12 AM
Senior Expert
APP Volunteer
Default
I assume it is updated as your old motherboard is no longer available. Generally suppliers force updates to prevent litigation.
As a servicer, I would replace both the motherboard and evaporator motor and add a 1000 joule surge protector to the wall outlet. Also I would add a slinger/umbrella to the motor shaft to prevent bearing failures to an expensive motor.
Read gene and my sticky post on this subject.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement. Gene Refrigerator & Freezer Repair 8 11-03-2008 01:26 PM
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 5 01-15-2008 10:49 AM
Evaporator Fan Motor chagan Refrigerator & Freezer Repair 1 01-08-2008 08:20 PM
evaporator fan motor niose toner Refrigerator & Freezer Repair 0 10-18-2007 10:46 AM
Freezer part cold, fridge part warm keithpar Refrigerator & Freezer Repair 1 10-08-2007 04:21 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
