Discuss
Kitchenaid Refrigerator Hot Door Frame
 in
Refrigerator & Freezer Repair
The refrigerator started acting weird this past week. The temperature inside the freezer was rising, refrigerator was also, but not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid Refrigerator Hot Door Frame
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-14-2008, 08:02 PM
billiardlo billiardlo is offline
Junior Member
billiardlo is on a distinguished road
Default Kitchenaid Refrigerator Hot Door Frame
Model Number: KSCS25INSS00   Brand: Kitchen Aid   Age: 1 - 5 years
The refrigerator started acting weird this past week. The temperature inside the freezer was rising, refrigerator was also, but not as bad. I vacuumed the coils underneath removing large amounts of dust. Somewhat better but, I checked the electric to the fan (it was not running but the compressor was) and did not get 115 volts. Additionally, the frame between the doors is very hot to touch. Any ideas of what might be wrong? I've set up a small fan behind the fridge to keep the compressor cool until I get your reply. KSCS25INSS00 ser# SR2433331 - Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-15-2008, 02:12 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Probably your microcomputer pc board in the back P#AP2993442 Just check for voltage output per your schematic to verify.
__________________
  #3 (permalink)
Old 02-08-2008, 08:31 AM
Junior Member
Default kitchenaid refrigerator problems
Thanks for you quick reply,
I have verified the compressor fan works. Should I be checking anything else before replacing this board? I have a portable fan blowing on the compressor and the door frame has remained cool. All else with the refrigerator/freezer seems to be working normally, except one thing. Before this issue with the fan not working, I remember hearing a suction noise after the freezer door was opened, then closed. That does not happen now. Is that related to the electronic control problem?
Thanks Bill
  #4 (permalink)
Old 02-18-2008, 02:18 PM
plabore plabore is offline
Junior Member
plabore is on a distinguished road
Angry I had the same problem.
I had the same problem. It turned out to be the circuit board that activates the compressor fan. One that was replaced the problem was solved. Unfortunately, it was out of warranty so the repair cost $350.00.
Now that the door frame has cooled down the liner has developed several hairline cracks down the center beam as well as in the corners. I spoke with Kitchenaid and they sent out white duct tape to put over the cracks. Their solution is to shut the unit off for 24 hrs, tape over the cracks, let it sit for another 24hrs and then turn the unit back on. That to me is unacceptable.
I spent a small fortune on a built in unit, the liner is still under warranty, yet Kitchenaid will not replace the liner, their solution is a duct tape band-aid.
I would love to hear if more people have experienced this problem. I've heard rumors of a class action suite against Kitchenaid regarding this. Does anyone know of this?
  #5 (permalink)
Old 02-19-2008, 05:44 AM
Junior Member
Default
Yeah, their customer service is terrible. If they "backed" their products better, I would have no complaints. It seems as soon as there is a problem, they run and don't provide any real solution. With that attitude, they will go the way Ford Motor Company is going, downhill, fast!
I had a repair man change the ELECTRONIC CONTROL BOARD but it did nothing. Can you tell me what part # you changed to recify? Perhaps I'm looking at the wrong part.
  #6 (permalink)
Old 06-05-2008, 08:19 PM
fumey fumey is offline
Junior Member
fumey is on a distinguished road
Default
P#AP2993442 ....... I've looked for this part # and cant find anything . I'm having the same issues with my refrigerator ... same model
  #7 (permalink)
Old 06-13-2008, 11:42 AM
vetthead vetthead is offline
Junior Member
vetthead is on a distinguished road
Default Same problem with freezer not working
Repair guy is here as I am typing. I have model kscs25inss, we purchased in Feb. 2005. Just recently starting having the issue of the freezer not freezing.
First service call the guy said that the control board was not working and it was not turning the fan on to cool the freezer.
The part they ordered was #2307028. My receipt says "Control H.V. Board." Our repair guy was a little worried because he said every thing looked identical to the part that was in the fridge except or one area. I think he said it was the ciricut or something.
He called tech support to confirm that it was the right part and they said it was.
He just installed it and it appears to be working. He said it took about 5 minutes for the fan to kick on.
Of course it was not under warranty! My cost was $195.00.
I am hoping this works. I will keep you posted.
  #8 (permalink)
Old 06-17-2008, 07:02 PM
mac383 mac383 is offline
Junior Member
mac383 is on a distinguished road
Default
I Am Having Hot Door Frame Issues And My Freezer Temp Was Climbing. I Cleaned Undedrneath And Got The Temp To Start To Drop But Still Have Heat Issue. Fan In Back Is Spinning.
Do I Replace The Control Board?
  #9 (permalink)
Old 06-18-2008, 02:27 AM
Senior Expert
APP Volunteer
Default
Sounds like you have a compressor going sour. Failing symptoms are a very hot compressor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Refrigerator vmill63 Refrigerator & Freezer Repair 2 01-09-2008 08:49 PM
Kitchenaid oven door kitoven Oven Repair (including Ranges and Cooktops) 1 12-03-2007 06:11 PM
Replacing Exterior Door Frame lpalmer Microwave Repair 0 11-21-2007 04:37 PM
kitchenaid superba refrigerator claire sullivan Refrigerator & Freezer Repair 0 09-30-2007 05:53 AM
Hot Frame between Fridge and Freezer mshilko Refrigerator & Freezer Repair 3 07-20-2007 12:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
