Discuss
Kenmore Fridge
 in
Refrigerator & Freezer Repair
Help wall was rotting. We didn't know that it was leaking from the top where it goes into the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Fridge
  #1 (permalink)
Old 01-14-2008, 07:32 PM
rjohnson rjohnson is offline
Junior Member
rjohnson is on a distinguished road
Default Kenmore Fridge
Model Number: 58642   Brand: Kenmore   Age: 5 - 10 years
Help wall was rotting. We didn't know that it was leaking from the top where it goes into the icemaker. The clamp wasn't doing the job anymore. It became worse after a birthday party when all the ice in the icemaker was used up and the icemaker quit working. My theory more water came out the back because it had nowhere to go. Please help we turned off the water supply and cleaned up the mold. My husband had seen a leak before and pulled out the refrig but it was nothing like what we found tonight thatfinally led us to the source. We took the hose loose and tried to push it back in but it still leaked how do we get a new part to connect the hose back so it won't leak?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-14-2008, 08:12 PM
ripleys ripleys is offline
Senior Expert
APP Volunteer
ripleys is on a distinguished road
Default
What you could try, providing you still have some length on the 1/4" water line is this...Make sure the ice maker fill tube is not frozen (remove if necessary to check) pulls out through back of fridge. Cut an inch off the plastic water line that pushes into the fill tube. Go to local hardware store or Home Depot. Buy a 1/4" copper tube compression fitting that has a plastic water line insert in the package. It looks like a small copper tube with a flared end that gets inserted into the end of the plastic tube to stop it from getting squashed or distorted when tightening up the clamp and install it back into the fill tube and tighten clamp.
Good Luck.
  #3 (permalink)
Old 01-14-2008, 08:16 PM
Junior Member
Default
Thanks so much!!! better than an expensive repair call. Now that you mention it I think the hose is frozen
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Side by side getting warm freezer and fridge tbonegrl Refrigerator & Freezer Repair 2 12-31-2007 03:52 PM
Kenmore Side by Side - Fridge Not Cooling pharmaman Refrigerator & Freezer Repair 3 10-11-2007 05:45 PM
Kenmore side-by-side fridge water dispenser Marvster Refrigerator & Freezer Repair 0 09-25-2007 01:34 PM
Kitchen Aid Fridge KSCS25FKSS00 is freezing on the fridge size shawnharper Refrigerator & Freezer Repair 0 09-03-2007 11:27 PM
Kenmore fridge - water drips into fridge njblue55 Refrigerator & Freezer Repair 3 08-07-2007 08:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
