Water comes through dispenser, but No water to trough in ice maker. Ice maker goes through its cycle ok. Disconnected sol's. used a jumper, both so's energized. Blew air through both sol's during test, both opened. Ther is a water line from sol's on back of refer that goes into the top of refer, disconnected tha line and blew air through, and that line wasn't clear. Recently replaced water filter thinking that could be it, but I do get water through disp. Any suggestions wouldbe helpful
Ray
Originally Posted by: raymand50 Water comes through dispenser, but No water to trough in ice maker. Ice maker goes through its cycle ok. Disconnected sol's. used a jumper, both so's energized. Blew air through both sol's during test, both opened. Ther is a water line from sol's on back of refer that goes into the top of refer, disconnected tha line and blew air through, and that line wasn't clear. Recently replaced water filter thinking that could be it, but I do get water through disp. Any suggestions wouldbe helpful
Ray Sounds like your inlet tube is frozen. That is the tube that goes through the back wall of the freezer to fill the IM. Sometimes when your water valve starts to go bad it doesn't completely shut off the flow of water and a very small amount leaks through and causes a gradual freeze over where it enters the freezer. Over time it causes a total ice blockage.
