Discuss
Evaporator Fan won't stop turning on and off
 in
Refrigerator & Freezer Repair
I replaced the evaporator fan, that's what cured the problem for me, my 20 yr old fridge has been running
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Evaporator Fan won't stop turning on and off
  #11 (permalink)
Old 04-02-2017, 06:06 PM
Junior Member
flugerbill is on a distinguished road
Default
I replaced the evaporator fan, that's what cured the problem for me, my 20 yr old fridge has been running fine ever since
  #12 (permalink)
Old 05-17-2017, 06:54 PM
Junior Member
Sunshines is on a distinguished road
Question Frigidaire side by side evaporator fan pulsing on an off
Quote:
Originally Posted by richappy View Post
You have a simple, mechanical cold control in this, most probably a bad/burnt wire to the evaporator motor.
After it comes to desired temp. It's an 02 model .the compressor is running fine it seems can you help me??
Last edited by Sunshines : 05-17-2017 at 06:58 PM. Reason: Not sue I'm do n the message right .
  #13 (permalink)
Old 05-17-2017, 07:09 PM
Junior Member
Default
I have an 02 Frigidaire side by side . The fan in the freezer is pulsing on /off after it reaches desired temp in freezer side an refrigerator side. What could cause this?? Do I unblug the refrigerator or let it run until I can get it checked out?
  #14 (permalink)
Old 12-03-2017, 06:03 PM
Junior Member
johnyyemon is on a distinguished road
Default
Quote:
Were you able to find a fix sunshines? It seems I have the same fridge one year newer with the same problem. I defrosted the evaporator coils, checked the fan it seems to be working properly but haven't put a meter on it. Any help would be great.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator evaporator fan not turning on jsteely Refrigerator & Freezer Repair 8 11-17-2013 01:32 PM
Evaporator Fan Blade not turning WendyLew Refrigerator & Freezer Repair 13 07-14-2010 11:57 AM
New motherboard not turning on compressor or evaporator fan jamievbva Refrigerator & Freezer Repair 0 11-27-2009 02:55 PM
Ice Maker won't stop turning daddyo Refrigerator & Freezer Repair 0 11-23-2008 10:43 PM
Roper dryer just stop turning and just hum. waynebowdean Dryer Repair 1 09-06-2008 08:29 PM
