Discuss
frig wont cut off
 in
Refrigerator & Freezer Repair
I replaced the evaporator fan motor due to excessive noise. frig would not shut off after this, however freezer temp
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » frig wont cut off
  #1 (permalink)
Old 03-17-2012, 06:14 AM
Junior Member
miked35 is on a distinguished road
Default frig wont cut off
Model Number: rsw 2400 eam   Brand: Maytag   Age: More than 10 years
I replaced the evaporator fan motor due to excessive noise. frig would not shut off after this, however freezer temp is 4degrees and frig temp is 36-40 degrees and fresh food bins temps are well below 32 degrees. i replaced the frig thermostat, same problem , frig wont shut off . please advise.
Thanks Mike D
Ads By Google
Related Models
Maytag RSW2200AAE Ref - SXS/I&W
Maytag RSW2200AAL Ref - SXS/I&W
Maytag RSW2200AAW Ref - SXS/I&W
Maytag RSW2200BAE Ref - SXS/I&W
Maytag RSW2200CAE Ref - SXS/I&W
Maytag RSW2200CAL Ref - SXS/I&W
Maytag RSW2200CAW Ref - SXS/I&W
Maytag RSW2200EAE Ref - SXS/I&W
Maytag RSW2200EAM Ref - SXS/I&W
International RSW2250AGE Ref - SXS/I&W
Maytag RSW22A Ref - SXS/I&W
Maytag RSW22E0CAE Ref - SXS/I&W
Maytag RSW22E0CAL Ref - SXS/I&W
Maytag RSW22E0DAE Ref - SXS/I&W
Maytag RSW22E0DAM Ref - SXS/I&W
Maytag RSW2400AAE Ref - SXS/I&W
Maytag RSW2400AAL Ref - SXS/I&W
Maytag RSW2400AAW Ref - SXS/I&W
International RSW2400AGE Ref - SXS/I&W
Maytag RSW2400BAE Ref - SXS/I&W
Maytag RSW2400CAB Ref - SXS/I&W
Maytag RSW2400CAE Ref - SXS/I&W
Maytag RSW2400CAL Ref - SXS/I&W
Maytag RSW2400CAW Ref - SXS/I&W
International RSW2400CKE Ref - SXS/I&W
International RSW2400CKL Ref - SXS/I&W
Maytag RSW2400EAB Ref - SXS/I&W
Maytag RSW2400EAE Ref - SXS/I&W
Maytag RSW2400EAM Ref - SXS/I&W
Maytag RSW2400EAW Ref - SXS/I&W
International RSW2400EKE Ref - SXS/I&W
International RSW2400EKM Ref - SXS/I&W
Maytag RSW24A Ref - SXS/I&W
Maytag RSW24B Ref - SXS/I&W
Maytag RSW24E0CAB Ref - SXS/I&W
Maytag RSW24E0CAE Ref - SXS/I&W
Maytag RSW24E0CAL Ref - SXS/I&W
Maytag RSW24E0CAW Ref - SXS/I&W
Maytag RSW24E0DAB Ref - SXS/I&W
Maytag RSW24E0DAE Ref - SXS/I&W
Maytag RSW24E0DAM Ref - SXS/I&W
International RSW24E0ZAE Ref - SXS/I&W
International RSW24E0ZAL Ref - SXS/I&W
International RSW24E0ZAM Ref - SXS/I&W
Maytag RSW2700DAB Ref - SXS/I&W
Maytag RSW2700DAE Ref - SXS/I&W
Maytag RSW2700DAM Ref - SXS/I&W
Maytag RSW2700EAB Ref - SXS/I&W
Maytag RSW2700EAE Ref - SXS/I&W
Maytag RSW2700EAM Ref - SXS/I&W
International RSW2700EKE Ref - SXS/I&W
International RSW2700EKM Ref - SXS/I&W
Amana RSW2TK24 Ele Cartridge
  #2 (permalink)
Old 03-17-2012, 09:41 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Is the evaporator fan blade turning the right way? It is shaped to cup the air and blow it away from the motor and into the fridg and freezer sections.
__________________
  #3 (permalink)
Old 03-17-2012, 12:37 PM
Junior Member
Default how
how do i reverse the blades direction?
Mike D
  #4 (permalink)
Old 03-18-2012, 01:31 AM
Senior Expert
APP Volunteer
Default
Either replace the blade with the correct one, or take the motor apart, if possible, and reverse the armature.
__________________
  #5 (permalink)
Old 03-18-2012, 06:26 AM
Junior Member
Default
Quote:
i was able to change the fan blades direction as recommended, however the frig still stayed on even after reaching 39degrees on top shelf and 21 degrees inside the bottom fresh food bins. the freezer temp is 4 degrees. the frig has run in excess of 18 hours without stopping since making the change of the evaporator fans direction of flow. what else could keep the compressor on continually?
thanks for your input
Mike D
  #6 (permalink)
Old 03-18-2012, 07:52 AM
Senior Expert
APP Volunteer
Default
Remove the lower crisper drawers and push in the door switch if needed to start the fan. If cold air is blowing out the lower vent, you have the air flow reversed, must have mounted the fan motor upside down!!
__________________
  #7 (permalink)
Old 03-18-2012, 08:46 AM
Junior Member
Default
at this point i have had the fan orienated both directions of flow. i saw in the schematic that there is a contact in the defrost timer that must be made for the compressor to work. is that a possibility?
thanks
mike d
  #8 (permalink)
Old 03-18-2012, 09:41 AM
Senior Expert
APP Volunteer
Default
The evaporator fan motor must blow cold air from the freezer into the upper
vent in the refrigerator so the cold control gets cold air directly from the freezer. If not, the fridg will never shut down.
__________________
  #9 (permalink)
Old 03-19-2012, 05:08 AM
Junior Member
Default follow up
thanks for your input rich. stiil the same situation, frig wont cut off. it is a side by side. i have tried all that you suggested. like i mentioned before i have reversed the evap fan direction with the frig still not cutting off. any thing else to look for?
Mike D
  #10 (permalink)
Old 03-19-2012, 07:36 AM
Senior Expert
APP Volunteer
Default
Verify the cold control will turn off the compressor. If so, that's probably ok, then measure the stabilized freezer temperature and post.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Frig, Temp freezing food in frig and water dispenser not working StamMKelly53 Refrigerator & Freezer Repair 10 02-05-2011 02:39 PM
Whirlpool Frig-Freezer good/Frig warm TD3 Refrigerator & Freezer Repair 5 12-18-2010 03:24 AM
GE frig freezer cold at bottom frig cool WRD0225 Refrigerator & Freezer Repair 0 08-16-2010 11:29 AM
frig wont quit making ice hvac_hillbilly Heating, Ventilation, and Air Conditioning (HVAC) 0 12-28-2009 07:07 PM
frig wont run gillis Refrigerator & Freezer Repair 4 01-27-2008 10:15 AM
