My icemaker was working fine until I turned off the water supply, without first putting the overflow arm of the icemaker in the "up" position. I assumed I had burned out the inlet valve, because it was making pumping noises (without delivering anything), so I replaced. Now I get no action, whereas before, even when broken, the old inlet valve made noises (but delivered no water). Is there another part I should be replacing?
