| » Kenmore fridge leaks water into fridge instead the drain tube |
Model Number: 25478137890 Brand: Kenmore Age: 1 - 5 years
Our refrigerator collects water inside instead of draining it through the drain tube - where can I look to find a manual, or which parts do I have to un-do to mnake sure the drain is not clogged?
Quote:
Good chance you do have a clogged drain. I'm not able to find the model # you have listed, but the drain is usually going to be on the back wall in the fresh food section. There is usually a cup the defrost water runs into and then runs down a tube on the back wall of the refrig. Not sure that is exactly the way, on this unit. Can you double check that model #?
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi Frank,
our landlord purchased the fridge for us from an estate sale, and I was trying to look up a manual, too. it seems the closest I can get to is 25 37 81 in the kenmore manual help, but it seems like a just "regular" top mount refrigerator with ice maker in that model line. The series is LA 80909516. I am usually pretty handy with taking things apart, I am just not sure where to take something off ;-) to get to de-clogging the drain line. You are right, there is a small drip cup inside the fridge, and a line in the back that is supposed to feed into the drip pan. Thanks, Sabrina |
Quote:
__________________
Hi again, your answer gave me enough confidence to get out the little drip cup in the fridge - no screws, just push-in-bolts. The drain was/is (?) indeed clogged, and I tried to push the stuff through. I had a hard time finding a workable angle to apply any pressure, air or water. So my last question: would it be safe to un-mount the cooling coils that are attached to the fridge with two screws on the back, on the outside? Then I could reach the drain pipe without twisting my fingers between the coils. Or should I leave the coils alone? Thanks again, Sabrina
Quote:
You can, just be careful. Don't let the coil drop down and potentially break one of the freon lines. Devise a way to prop it up, so it just gives you enough room to get in there and do what you need to do.
__________________
| Display Modes | |
| Fridge leaks water | sage | Refrigerator & Freezer Repair | 0 | 01-07-2010 04:16 PM |
| Water resevoir leaks in fridge | Bud Wiser | Refrigerator & Freezer Repair | 0 | 09-07-2009 09:58 AM |
| Leaks water in bottom of fridge | nitroman | Refrigerator & Freezer Repair | 1 | 04-04-2009 03:00 PM |
| kenmore fridge leaks on floor | mikkonen | Refrigerator & Freezer Repair | 1 | 07-23-2008 06:33 PM |
| Kenmore fridge - water drips into fridge | njblue55 | Refrigerator & Freezer Repair | 3 | 08-07-2007 07:50 PM |
