Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   Electrical Wire Connectors (http://forum.appliancepartspros.com/refrigerator-freezer-repair/440138-electrical-wire-connectors.html)
gfm 03-15-2012 12:10 PM
The receptors on the replacement relay (pn 2188830) for the compressor relay are not the same size as the old one. Do I need to replace the connectors or buy additional wire with corect size connectors? Also, I had three clearly marked connections (white, blue and red wires) on the old device, but I see only two on the replacement device--what did I miss.
gfm
richappy 03-15-2012 01:29 PM
Put the right model # in the box.
gfm 03-15-2012 02:20 PM
Refrigerator Model is KSRG25fkss03
New relay part number is2188830
Old relay part number is 2212194
compressor type is EGY 90
gfm 03-15-2012 03:20 PM
Part ID (new relay) is also 820 1786
Gene 03-15-2012 03:51 PM
The start device with the part number 8201786, which is APP Part number: AP3885081
is the correct part for your refrigerator. It comes with the installation instructions, so you would be able to choose the right piece for your compressor.
