Steve
Evaporator fan not moving air around freezer causing thawing in top half of freezer and refrig becomming warm. Replaced evaporation fan (ap3875639) and still will not run. Is there a way to test sensor temp ff (ap3185407) or thermostat def (ap3884317). Is there something else I should consider?
If you have a meter, check out the "sticky" article by Gene. You will need to replace the mother board in the back of fridg. P# AP3950129
| All times are GMT -7. The time now is 05:49 PM. |
