Discuss
Whirlpool Icemaker not working
 in
Refrigerator & Freezer Repair
I cannot keep my icemaker working in my whirlpool frig. I have bought probably 4 icemakers and after a few
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Icemaker not working
  #1 (permalink)
Old 01-13-2008, 04:05 PM
jparte01 jparte01 is offline
Junior Member
jparte01 is on a distinguished road
Default Whirlpool Icemaker not working
Model Number: ED22PQXDW02   Brand: Whirlpool   Age: More than 10 years
I cannot keep my icemaker working in my whirlpool frig. I have bought probably 4 icemakers and after a few months to a year they have all quit working. The factory icemaker that came with the frig lasted the longest. The last one I bought (last October 2007) made ice for only a couple of months and it just quit producing ice, no warnings or wierd sounds. I have ckecked the fuse in the wire harness and there is continuity. I can pour water manually into the mold and it will cycle. But it doesn't seem to be calling for water or it is calling and not getting water. The ice makers prior to the last one made shells after a few months and then eventually quite working. I don't know what else to do and I am tired of buying ice makers. The freezer thermometer says 5 deg. Can you give me some advice?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-14-2008, 06:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is remove the cover from the ice maker and increase the water fill amount by turning the adjustment screw CCW for about 180°.
If it would not help, then check for 120V coming to the water valve when the ice maker calls for water (the ejector blades are in 11:00 o'clock position). The power should present for about 7.5 to 9 seconds.
Do not rotate the blades or the drive gear manually - it will damage the ice maker. If you need to advance the ice maker into the cycle, use a jumper (insulated piece of wire at least 14GA) to short the test points T & H. The shut-off arm must be in "on" position.
If there is no power, then the problem is the wiring or the ice maker itself.
If there is power, then the problem is the water inlet valve.
Post the results, please.
- The part number for the water inlet valve is AP3085178
- The part number for the replacement ice maker is AP2984633
- Here are the break down diagrams for the Whirlpool refrigerator Model ED22PQXDW02
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-14-2008, 08:25 PM
Junior Member
Default
where do I check the power at on the ice maker?
  #4 (permalink)
Old 01-14-2008, 08:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jparte01 View Post
....I can pour water manually into the mold and it will cycle.....
It proves there is the power to the ice maker.
__________________
  #5 (permalink)
Old 01-14-2008, 08:43 PM
Junior Member
Default
I just tried to cross t and h with a wire, but the ejector blades did not rotate. Currently the ejector pins are in the 2:00 position and I have current across L-N and T-H, but no where else.
  #6 (permalink)
Old 01-14-2008, 08:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is 120V across T & H, then the motor in the the ice maker is bad and the ice maker has to be replaced.
__________________
  #7 (permalink)
Old 01-14-2008, 08:57 PM
Junior Member
Default
Thank you very much. You've been a big help.
  #8 (permalink)
Old 01-14-2008, 09:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #9 (permalink)
Old 04-12-2008, 04:18 PM
ken311 ken311 is offline
Junior Member
ken311 is on a distinguished road
Angry Whirlpool Frig Model GS5SHAXNT00
My ice maker is inop. I did a full optics diagnostic for 2002 design boards and all checked IAW the proceedure. I am concrened that I do NOT have pwer (Volts) at the icemaker. Where/how do I check the power at on the ice maker connector/frig freezer side? I have volts on the Black wire in back if the frig at the connector...but i don't know if it is at the connect in the freezer.
With the icemaker installed, there is no Volts across L-N. I ohmed L to the ice recepticle black wire with .5 ohms. So, the thermal is not blown, correct?
  #10 (permalink)
Old 04-12-2008, 05:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
ken311,
Check the wire harness by the bottom freezer door hinge.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
icemaker working slow smiley General Talk 3 06-11-2008 12:41 PM
Kitchenaid Icemaker not working jayconnor Refrigerator & Freezer Repair 19 04-26-2008 02:05 PM
Icemaker not working KenMoore Refrigerator & Freezer Repair 0 11-30-2007 11:31 AM
Icemaker not working dj928 Refrigerator & Freezer Repair 0 10-12-2007 01:21 PM
Whirlpool Icemaker parparsons Refrigerator & Freezer Repair 1 07-25-2007 03:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
