Discuss
Amana Refrigerator freezer - not cold
 in
Refrigerator & Freezer Repair
Freezer not cooling enough to make cubes, water appears on floor at RHS of freezer. Do not have ice maker.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Refrigerator freezer - not cold
  #1 (permalink)
Old 08-10-2009, 04:36 PM
Junior Member
ipbun is on a distinguished road
Default Amana Refrigerator freezer - not cold
Model Number: BX22   Brand: Amana   Age: More than 10 years
Freezer not cooling enough to make cubes, water appears on floor at RHS of freezer. Do not have ice maker. A motor runs all the time not sure if its compressor or evaporator fan. we have freexer compartment empty and inside back panel removed.
where can the water be coming from, what should we check ?
DIY book says we might have a clogged drain but the only one we can see is in the freezer and that appears clear, certainly not clogged with ice.
Help ?
Ads By Google
Related Models
Amana BX22A2E Ref - Bottom Mounts
Amana BX22A2L Ref - Bottom Mounts
Amana BX22A2W Ref - Bottom Mounts
Amana BX22A5L Ref - Bottom Mounts
Amana BX22A5W Ref - Bottom Mounts
Amana BX22R3E Ref - Bottom Mounts
Amana BX22R3L Ref - Bottom Mounts
Amana BX22R3W Ref - Bottom Mounts
Amana BX22RE Ref - Bottom Mounts
Amana BX22RL Ref - Bottom Mounts
Amana BX22RW Ref - Bottom Mounts
Amana BX22S5E Ref - Bottom Mounts
Amana BX22S5L Ref - Bottom Mounts
Amana BX22S5W Ref - Bottom Mounts
Amana BX22TE Ref - Bottom Mounts
Amana BX22TL Ref - Bottom Mounts
Amana BX22TW Ref - Bottom Mounts
Amana BX518VE Ref - Bottom Mounts
Amana BX518VW Ref - Bottom Mounts
Amana BX521VCPER Ref - Bottom Mounts
Amana BX521VCPSR Ref - Bottom Mounts
Amana BX521VCPWR Ref - Bottom Mounts
Amana BX521VE Ref - Bottom Mounts
Amana BX521VW Ref - Bottom Mounts
Amana BXF19TL Ref - Bottom Mounts
Amana BXF19TW Ref - Bottom Mounts
Amana BXI21VE Ref - Bottom Mounts
Amana BXI21VL Ref - Bottom Mounts
Amana BXI21VW Ref - Bottom Mounts
Amana BXI22S5E Ref - Bottom Mounts
Amana BXI22S5L Ref - Bottom Mounts
Amana BXI22S5W Ref - Bottom Mounts
Whirlpool BYCCD3421W0
Whirlpool BYCCD3421W1
Whirlpool BYCCD3421W2
Whirlpool BYCCD3421W3
Whirlpool BYCCD3921W0
Whirlpool BYCD3722W0
Whirlpool BYCD3722W1
Whirlpool BYCD3723W0
Whirlpool BYCD3723W1
Whirlpool BYCD3723W2
Whirlpool BYCD4932W0
Whirlpool BYCD4933W0
Whirlpool BYCW4271W0
Whirlpool BYCW6292W0
Whirlpool BYCWD6274W0
Whirlpool BYCWD6274W1
Whirlpool BYCWD6274W2
Whirlpool BYCWD6274W3 Washer/dryer Laundry System
Whirlpool BYCWD6274W4 Washer/dryer Laundry System
Amana BZ20QE Ref - Bottom Mounts
Amana BZ20QG Ref - Bottom Mounts
Amana BZ20QL Ref - Bottom Mounts
Amana BZ20QW Ref - Bottom Mounts
Amana BZ20R Ref - Bottom Mounts
Amana BZ20RE Ref - Bottom Mounts
Amana BZ20RG Ref - Bottom Mounts
Amana BZ20RL Ref - Bottom Mounts
Amana BZ20RW Ref - Bottom Mounts
Amana BZ22QE Ref - Bottom Mounts
Amana BZ22QL Ref - Bottom Mounts
Amana BZ22QW Ref - Bottom Mounts
Amana BZ22R3E Ref - Bottom Mounts
Amana BZ22R3L Ref - Bottom Mounts
Amana BZ22R3W Ref - Bottom Mounts
Amana BZ22R5L Ref - Bottom Mounts
Amana BZ22R5W Ref - Bottom Mounts
Amana BZ22RE Ref - Bottom Mounts
Amana BZ22RL Ref - Bottom Mounts
Amana BZ22RW Ref - Bottom Mounts
Jenn-Air C Surface Unit - Ddraft Ele
Amana C-11 Freezer - Chest
Amana C-15 Freezer - Chest
Amana C-19 Freezer - Chest
Amana C-28 Freezer - Chest
Hardwick C-413 Surface Unit - Gas
Hardwick C-414 Surface Unit - Gas
Hardwick C-423 Surface Unit - Gas
Hardwick C-424 Surface Unit - Gas
Hardwick C-433 Surface Unit - Gas
Hardwick C-434 Surface Unit - Gas
Hardwick C-443 Surface Unit - Gas
Hardwick C-444 Surface Unit - Gas
Jenn-Air C100 Surface Unit - Ddraft Ele
Amana C100DW Freezer - Chest
Amana C100FW Freezer - Chest
  #2 (permalink)
Old 08-11-2009, 03:35 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Your insulation is thawing from the warm temperatures. Pull off the back panel and check if the condensing fan and compressor are running.
__________________
  #3 (permalink)
Old 08-11-2009, 05:56 AM
Junior Member
Default
Thanx for the reply. Took off outer back panel, condenser fan, and compressor all appear to be running. I can see/feel the fans and the compressor is hot so I'm assuming that means it has run. Took off freezer inside back panel, heat ex coils are getting cold and forming ice, evaporator fan is running
We cleaned out freezer last night and overnight the unit only got to 28 Deg F , is it possible a leaky door seal is our sole problem ? The refrigerator is keeping cool, but not cold .
Is the insulation water filled or is it just frozen condensation ?
thanks for your help - what next steps do you suggest
Ian
  #4 (permalink)
Old 08-11-2009, 06:17 AM
Senior Expert
APP Volunteer
Default
Call a pro to look at it, you have system problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigeratior/Freezer too cold stevetijeras Refrigerator & Freezer Repair 3 02-23-2010 01:42 PM
Amana freezer won't get cold enough 3handygals Refrigerator & Freezer Repair 1 09-30-2009 03:49 PM
Amana refrigerator not cold dppham Refrigerator & Freezer Repair 0 01-23-2009 08:20 AM
Amana SbyS Freezer not cold kdex Refrigerator & Freezer Repair 1 05-22-2008 11:37 AM
Amana Bottom Freezer Refrigerator won't get cold again nascarfan Refrigerator & Freezer Repair 0 04-17-2008 09:41 AM
