| » GE Ice Maker Problem |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: ZDIS15 Brand: GE Age: 1 - 5 years
We have a GE free-standing ice maker, ZDIS15. It is having a problem releasing the sheet of ice to the cutting grid. System seems to run on a timed schedule and once the ice making phase is done it stops flowing water and refills the water reservoir. During that time, the sheet does show some signs of loosening and makes some cracking noises but will not slide out so when the next cycle starts, it builds up more ice on top of the existing sheet and so on. If you turn the unit off right after the ice production cycle stops, the ice will melt enough to slide out on its own in about 5 minutes. You can then turn it back on and repeat the same process. Does the ice maker heat the plate to break it free or what is suppose to cause the sheet of ice to free itself from the plate? We did clean everything many times! Any ideas?
Did you both use the nickle cleaner to clean the machine. There is something, either a dirty cold plate or something that is keeping it from sliding. The cold plate does heat up from the compressor. It uses a reversing valve to put the hot refrigerant through the cold plate to release it. It does not use a heater.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| Thanksgiving Oven Problem.....its still a Problem! | rbmattila | Oven Repair (including Ranges and Cooktops) | 1 | 03-03-2008 09:05 AM |
| Ice Maker problem | Tony Merkevicius | Refrigerator & Freezer Repair | 1 | 11-27-2007 12:26 PM |
| Ice Maker problem | Claypoole | Refrigerator & Freezer Repair | 2 | 10-25-2007 04:05 AM |
| Ice maker problem | scoots1925 | Refrigerator & Freezer Repair | 1 | 09-26-2007 09:22 AM |
