Discuss
not cooling
 in
Refrigerator & Freezer Repair
Side by side freezer/frig. It is not cooling, the coils inside the freezer compartment are not getting cold. It seems
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » not cooling
  #1 (permalink)
Old 03-09-2012, 10:39 PM
Junior Member
coloradotrout is on a distinguished road
Default not cooling
Model Number: GD25DFXFW02   Brand: Whirlpool   Age: More than 10 years
Side by side freezer/frig. It is not cooling, the coils inside the freezer compartment are not getting cold. It seems like the compressor tries to start, but then stop within a few seconds. After awhile it will retry. I'm going to pull it out from the wall in the am and take another look. How can I determine if it's the relay/starter or the compressor?
Ads By Google
Related Models
Whirlpool GD25DFXFW02
Whirlpool GD25DFXFW03
Whirlpool GD25DIXHB00
Whirlpool GD25DIXHB02
Whirlpool GD25DIXHS00
Whirlpool GD25DIXHS02
Whirlpool GD25DIXHT00
Whirlpool GD25DIXHT02
Whirlpool GD25DIXHW00
Whirlpool GD25DIXHW02
Whirlpool GD25DQXFB00
Whirlpool GD25DQXFB01
Whirlpool GD25DQXFN00
Whirlpool GD25DQXFN01
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
Whirlpool GD27DIXHS02
Whirlpool GD27DIXHT00
Whirlpool GD27DIXHT01
Whirlpool GD27DIXHT02
Whirlpool GD27DIXHW00
Whirlpool GD27DIXHW01
Whirlpool GD27DIXHW02
Whirlpool GD27DQXFB00
Whirlpool GD27DQXFB01
Whirlpool GD27DQXFN00
Whirlpool GD27DQXFN01
Whirlpool GD27DQXFW00
Whirlpool GD27DQXFW01
Whirlpool GD2LHGXKB00
Whirlpool GD2LHGXKQ00
Whirlpool GD2LHGXKT00
Whirlpool GD2LHGXLB00
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03
Whirlpool GD2LHGXLB04
Whirlpool GD2LHGXLQ00
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03
Whirlpool GD2LHGXLQ04
Whirlpool GD2LHGXLT00
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03
Whirlpool GD2LHGXLT04
Whirlpool GD2NHAXMB00 Refrigerator
Whirlpool GD2NHAXMQ00 Refrigerator
Whirlpool GD2NHAXMT00 Refrigerator
Whirlpool GD2NHGXKB01
Whirlpool GD2NHGXKB02
Whirlpool GD2NHGXKQ01
Whirlpool GD2NHGXKQ02
Whirlpool GD2NHGXKT01
Whirlpool GD2NHGXKT02
Whirlpool GD2NHGXLQ00
Whirlpool GD2NHGXLT00
Whirlpool GD2SHAXKB01
Whirlpool GD2SHAXKB02
Whirlpool GD2SHAXKB03
Whirlpool GD2SHAXKQ01
Whirlpool GD2SHAXKQ02
Whirlpool GD2SHAXKQ03
Whirlpool GD2SHAXKT01
Whirlpool GD2SHAXKT02
Whirlpool GD2SHAXKT03
Whirlpool GD2SHAXLB00
Whirlpool GD2SHAXLB02
Whirlpool GD2SHAXLQ00
Whirlpool GD2SHAXLQ02
Whirlpool GD2SHAXLT00
Whirlpool GD2SHAXLT02
Whirlpool GD2SHAXMB00 Refrigerator
Whirlpool GD2SHAXMQ00 Refrigerator
Whirlpool GD2SHAXMT00 Refrigerator
Whirlpool GD2SHAXNB00 Refrigerator
Whirlpool GD2SHAXNB01 Refrigerator
Whirlpool GD2SHAXNL00 Refrigerator
Whirlpool GD2SHAXNL01 Refrigerator
Whirlpool GD2SHAXNQ00 Refrigerator
Whirlpool GD2SHAXNQ01 Refrigerator
Whirlpool GD2SHAXNS00 Refrigerator
Whirlpool GD2SHAXNS01 Refrigerator
Whirlpool GD2SHAXNT00 Refrigerator
  #2 (permalink)
Old 03-10-2012, 04:06 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If the noise is from the compressor, pry off the side cover. Take a picture or note down which wires go where, then pry off the start device, a small, black or brown device. With an ohmeter, check resistance across it, should be between 5 and 10 ohms. If open, or you have no meter, just order a new one AP3083556
__________________
  #3 (permalink)
Old 03-11-2012, 02:48 PM
Junior Member
Default
I pulled off the start device/relay and per another thread here shook it. It sounded like an egg shaker with small metalic parts falling out. I did not bother to ohm check.
  #4 (permalink)
Old 03-13-2012, 03:40 PM
Junior Member
Default
I got the part, AP3083556, which has 4 parts - a cover, 2 electrical parts, and 1 small plastic-only piece. My old part was just 1 unit. I plugged-in the two electrical parts. I had to cut off the old connector that had the two white wires going to it and replace it with a bit larger connector to fit over the spade on the new part. But what is that small plastic only part for?
  #5 (permalink)
Old 03-13-2012, 05:14 PM
Junior Member
Default
My old one sort of looks like this WHIRLPOOL Overload/relay, part number: AP4077400, but not quite. The part richhappy suggested seems to be working, but I've connected the two electrical parts. I still can't figure out where the small plastic part should go - do I need to?
  #6 (permalink)
Old 03-14-2012, 01:32 AM
Senior Expert
APP Volunteer
Default
I assume you stuck the klixon, a narrow white part to the common pin on top and the black ptc device in the bottom two pins.
If so, did you wire in the run capacitor ? Also, how did you know how to wire in the ptc device?
__________________
  #7 (permalink)
Old 03-14-2012, 07:57 AM
Junior Member
Default
Referencing this diagram, Unit replacement parts for Whirlpool GD25DFXFW02 SIDE BY SIDE REFRIGERATOR | AppliancePartsPros.com, (my model and the unit blowup), I put on parts 13, 15, and 12. 13 was narrow and white and one pin, 15 was all black and 2 pins. 13 went onto the compressor 1st, and then 15. They sort of fit into one another. I put the wires on based on the layout of the old part. Top and toward the door of the frig were 2 white wires. I had to cut off that connector because the spade on the new part (#15) was wider than the old part and replace with a new connector. Top and towards the back of the frig was the blue wire. Bottom was the red wire (red connected to part 13).
There is no capacitor in this area that I can see -- either on the old part, or the new part I installed.
These http://www.appliancepartspros.com/Ap...ap3083556.aspx are the parts I got.
To the left is the cover #12, top center is #13, bottom center is #15, and to the bottom right is the plastic only part that I don't know what to do with.
Is there suppose to be a capacitor somewhere? And is that small plastic part needed?
  #8 (permalink)
Old 03-14-2012, 08:22 AM
Senior Expert
APP Volunteer
Default
Looks like you got an extra ptc device, you should be ok if you followed the directions. Apparently your fridg never had a run capacitor, so you are ok there too.
__________________
  #9 (permalink)
Old 03-14-2012, 09:08 AM
Junior Member
Default
Well.. there were no instructions. None.
That other part is just a piece of plastic. It's the bottom right hand side piece here: http://www.appliancepartspros.com/Ap...ap3083556.aspx
and it's just a piece of plastic -- no electrical parts, etc.
I'm going to ask support for the instructions.
  #10 (permalink)
Old 03-14-2012, 09:09 AM
Junior Member
Default
Did I get the right part for my model?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frig stops cooling adjust thermastat and it starts cooling again Henry123 Refrigerator & Freezer Repair 1 01-18-2012 08:12 AM
Frigidaire FRS26R4AW6 stops cooling, starts cooling after unplugged. ckdorsey Refrigerator & Freezer Repair 1 11-01-2011 04:30 AM
refridgerator not cooling. freezer is cooling fine Debbie Ash Refrigerator & Freezer Repair 0 08-24-2011 10:17 AM
Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling angiebritt Refrigerator & Freezer Repair 3 07-22-2010 04:28 PM
cooling side is not cooling thomasthediep Refrigerator & Freezer Repair 11 10-03-2008 05:51 AM
