The water line froze up in the water dispenser line. I used a hair dryer and small screw driver to remove the ice. Apparently the line is now split and trickles a little water between the spout and wall the spout comes out of. I was going to replace the tube, but would not pull it out from the bottom. I started to pull the spout out from the top, but was afraid of damaging the frame or spout.
How can I replace this water line in this model?
Groups: Guests
Hello. This particular model has not got a replacement water line listed. That means that the water line in the door is only available with the complete door assembly [AP3872859]. I hope this was useful information. Have a great day!
