| » Amana refigerator |
Model Number: SRD22S5E Brand: Amana Age: 5 - 10 years
Freezer fan works, Fridge fan works. Refrigerant was told ok. When I turn freezer temp to max cold, fan does not come on. Freezer was never really cold enough anyway.what else do I need to check/replace so I can use the appliance...
Hello. This model is wired a bit different from most models. The problem is most likely the defrost thermostat [AP4247469]. Be aware that on this design, the evaporator fan doesn't get voltage to it until the defrost thermostat is chilled down to below 50°F. It takes approximately 8 to 10 minutes of run time before this occurs, so when the part is replaced, you have to allow it about 10 minutes before you deem the repair a non-success. I hope this was useful information for you!
Did as instructed, freezer is chillen nice, but the thing wont shut down. I let the fridge run overnight and when I got up, the thing was still running, so I turn the thermostat counterclockwise to lower its temp to see if the fan would stop but it didn't. It would only stop if I turned it to off. ???????
| Display Modes | |
| Refigerator | gohuntr | Refrigerator & Freezer Repair | 1 | 12-27-2011 04:21 AM |
| Refigerator | jferguson | Refrigerator & Freezer Repair | 1 | 08-25-2011 07:30 AM |
| refigerator | redtruck | Refrigerator & Freezer Repair | 0 | 01-25-2011 09:13 AM |
| refigerator | pramode seth | Refrigerator & Freezer Repair | 0 | 04-30-2010 03:22 PM |
| refigerator | ing84 | Refrigerator & Freezer Repair | 1 | 02-16-2009 02:52 PM |
