Hello, I am having a problem with our Kitchen Aid KSCS25FKSS01 side by side refigerator door seal. The hinges are fine, the alignment good and the bushings are tight. The refigerator side door does not want to stay closed, the freezer side is fine. The door sticks out further that the freezer door (when closed) and very easily pops open. The black seal looks fine but appears slightly thicker than the seal on the freezer door. I am on the verge of ordering a new seal but I don't want to spend over $100 on a part that I am not sure is bad. The refigerator is only five years old. Any help or advice would be greatly appreciated. The refegerator seems to be cooling as it should, the door is the only issue I have. Thank you!
