Discuss
Problem with the water dispenser
 in
Refrigerator & Freezer Repair
Hi There, Yes I am having difficulty with the water dispenser. It no longer works, the icemaker does however and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Problem with the water dispenser
  #1 (permalink)
Old 08-06-2009, 11:08 AM
Junior Member
gordonsc is on a distinguished road
Default Problem with the water dispenser
Model Number: GD25DQXFW01   Brand: Whirlpool   Age: 5 - 10 years
Hi There,
Yes I am having difficulty with the water dispenser. It no longer works, the icemaker does however and when I lower the arm in the freezer you can hear the water charging/filling the tray so I don’t believe I have a problem with the water line from the filter to the valve. I do not have a repair manual but wondered if there is a double solenoid valve that allows water for ice or water for the dispenser when activated at the dispenser. How can I troubleshoot to verify a bad valve? Do I test for the signal at the solenoid? What aspects am I missing from the troubleshooting guide if it is not the valve?
Ads By Google
Related Models
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
Whirlpool GD27DIXHS02
Whirlpool GD27DIXHT00
Whirlpool GD27DIXHT01
Whirlpool GD27DIXHT02
Whirlpool GD27DIXHW00
Whirlpool GD27DIXHW01
Whirlpool GD27DIXHW02
Whirlpool GD27DQXFB00
Whirlpool GD27DQXFB01
Whirlpool GD27DQXFN00
Whirlpool GD27DQXFN01
Whirlpool GD27DQXFW00
Whirlpool GD27DQXFW01
Whirlpool GD2LHGXKB00
Whirlpool GD2LHGXKQ00
Whirlpool GD2LHGXKT00
Whirlpool GD2LHGXLB00
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03
Whirlpool GD2LHGXLB04
Whirlpool GD2LHGXLQ00
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03
Whirlpool GD2LHGXLQ04
Whirlpool GD2LHGXLT00
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03
Whirlpool GD2LHGXLT04
Whirlpool GD2NHAXMB00 Refrigerator
Whirlpool GD2NHAXMQ00 Refrigerator
Whirlpool GD2NHAXMT00 Refrigerator
Whirlpool GD2NHGXKB01
Whirlpool GD2NHGXKB02
Whirlpool GD2NHGXKQ01
Whirlpool GD2NHGXKQ02
Whirlpool GD2NHGXKT01
Whirlpool GD2NHGXKT02
Whirlpool GD2NHGXLQ00
Whirlpool GD2NHGXLT00
Whirlpool GD2SHAXKB01
Whirlpool GD2SHAXKB02
Whirlpool GD2SHAXKB03
Whirlpool GD2SHAXKQ01
Whirlpool GD2SHAXKQ02
Whirlpool GD2SHAXKQ03
Whirlpool GD2SHAXKT01
Whirlpool GD2SHAXKT02
Whirlpool GD2SHAXKT03
Whirlpool GD2SHAXLB00
Whirlpool GD2SHAXLB02
Whirlpool GD2SHAXLQ00
Whirlpool GD2SHAXLQ02
Whirlpool GD2SHAXLT00
Whirlpool GD2SHAXLT02
Whirlpool GD2SHAXMB00 Refrigerator
Whirlpool GD2SHAXMQ00 Refrigerator
Whirlpool GD2SHAXMT00 Refrigerator
Whirlpool GD2SHAXNB00 Refrigerator
Whirlpool GD2SHAXNB01 Refrigerator
Whirlpool GD2SHAXNL00 Refrigerator
Whirlpool GD2SHAXNL01 Refrigerator
Whirlpool GD2SHAXNQ00 Refrigerator
Whirlpool GD2SHAXNQ01 Refrigerator
Whirlpool GD2SHAXNS00 Refrigerator
Whirlpool GD2SHAXNS01 Refrigerator
Whirlpool GD2SHAXNT00 Refrigerator
Whirlpool GD2SHAXNT01 Refrigerator
Whirlpool GD2SHGXKB01
Whirlpool GD2SHGXKB02
Whirlpool GD2SHGXKQ01
Whirlpool GD2SHGXKQ02
Whirlpool GD2SHGXKT01
Whirlpool GD2SHGXKT02
Whirlpool GD2SHGXLB00
Whirlpool GD2SHGXLB01
Whirlpool GD2SHGXLQ00
Whirlpool GD2SHGXLQ01
Whirlpool GD2SHGXLT00
Whirlpool GD2SHGXLT01
Whirlpool GD2SHKXKQ00
Whirlpool GD2SHKXKQ01
  #2 (permalink)
Old 08-06-2009, 02:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Locate the water inlet valve on the back of the refrigerator. Remove the wires from the water dispenser solenoid (5/16" tube) and check for 120 VAC between these wires while the water dispenser calls for water. Replace the water valve if there is proper voltage.
- The water valve Part number: AP3085178
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GD25DQXFW01 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-10-2009, 02:10 PM
Junior Member
Default
Gene,
I tested out and got the signal indicating failure of the water side of the inlet valve. I looked at the part and am assuming that it mates with the existing outer inlet for the water. Is this the case and would I need any o-rings or anything else?
  #4 (permalink)
Old 08-10-2009, 04:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is correct voltage reading then you don't need anything else but the water valve.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Dispenser Problem grixsil Refrigerator & Freezer Repair 1 06-15-2009 06:50 PM
Water Dispenser Problem fabspe Refrigerator & Freezer Repair 2 04-08-2009 06:41 PM
Problem With Water Dispenser tonyspar72 Refrigerator & Freezer Repair 8 10-21-2008 11:17 PM
Water dispenser problem Nance Refrigerator & Freezer Repair 0 05-27-2008 09:52 AM
Water dispenser problem Noose Refrigerator & Freezer Repair 2 12-29-2007 12:45 PM
