Discuss
Removing Freezer door/water line on side-by-side to install new cam riser
 in
Refrigerator & Freezer Repair
The cam riser on the bottom of my freezer door is shot so I am trying to replace it so
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Removing Freezer door/water line on side-by-side to install new cam riser
  #1 (permalink)
Old 03-05-2012, 09:00 AM
Junior Member
RSMBob is on a distinguished road
Default Removing Freezer door/water line on side-by-side to install new cam riser
Brand: GE   Age: More than 10 years
The cam riser on the bottom of my freezer door is shot so I am trying to replace it so the door closes/seals better (it now pops open whenever you shut the refrigerator door). I replaced the one on the refrigerator a while back, but the freezer adds an additional complication of the water line tube for the ice-maker going through the cam riser. I can't get the door off to replace the cam riser without removing the water line. The question is how do I easily remove the water line and then re-install it.
FYI, model is GE TFX24RLJ. Thanks for any and all advice.
  #2 (permalink)
Old 03-05-2012, 09:33 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Bob, First you'll need to remove the kickplate/grill panel on the front bottom of the refrigerator. Find the water tube coupler
Part number: AP2060230
Loosen and disconnect the coupler portion installed on the tube that goes to the hinge assembly and remove the nut on the water tube. Of course you've already unplugged the power cord and turned the water supply to the refrigerator off. You'll also need to separate the electrical wire harness as well. Then remove the freezer door upper hinge cover and three screws that hold the hinge to the refrigerator cabinet. Carefully lift the complete door up and off the hinge, and set it on a blanket on the floor, hinge side up. Replace the cams and lifters as necessary, and lubricate liberally with silicone based grease. Reverse the prodecure, make sure you align the door properly, and the properly tighten the top hinge screws and test and flush the water dispenser at the door.
Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-05-2012, 12:20 PM
Junior Member
Default
Many thanks for the clear concise advice. It turns out that BOTH the cam risers...the one attached to the door AND the one attached to the hinge...are bad. I'm assuming for the door one I need to buy the whole hinge assembly since the cam riser is bolted on.
  #4 (permalink)
Old 03-05-2012, 01:37 PM
Senior Expert
Default
Bob,
Yes, You're correct, you'll need the hinge assembly,
Part number: AP2063068
I apologize, I forgot to attach the part number for you, on my previous post.
Thanks Again,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 03-24-2015, 10:46 AM
Junior Member
Gary the fixer is on a distinguished road
Default
Quote:
Originally Posted by Joe / APP Team View Post
Bob,
Thanks Again,
Great video. Although 1 thing is omitted. I received my hinge, with bottom cam attached. But, it also came with the top cam. In order to replace the top cam, the freezer door must be removed to get at the little bolts that hole the cam keeper in place.
  #6 (permalink)
Old 03-24-2015, 11:36 AM
Senior Expert
Default
Quote:
Gary,
Thanks for the additional information,
it'll come in handy for others using the forum Great Job.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how do I replace water line in freezer door of whirlpool side by side Todd Overton Refrigerator & Freezer Repair 35 08-09-2016 05:40 PM
How do I replace the water line in freezer door of GE side by side? bthoma121 Refrigerator & Freezer Repair 4 08-11-2011 02:40 AM
Side by Side model freezer door keeping water line frozen fisshen99 Refrigerator & Freezer Repair 0 11-14-2010 02:12 PM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 1 03-30-2010 11:18 PM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 0 03-21-2010 08:04 PM
